Aug 16, 2013 19:22:45 GMT
Hi
There was a classic car restorer based in wales which fitted a early 70s datsun body unto a modern car platform, (think it may have been a mx5 with the body cut off) can't find his detail anywhere. I have a 70 triumph herald in a bad state and toying with the idea of fitting the top half onto a modern floor. Mainly for reliability and for mods such as PS etc as car is for my father who suffers from arthritis. Can anyone recommend a garage who can undertake this kind of project/who has done similar projects in the past and who's rates are reasonable.
Regards
Razi
kram
Aug 16, 2013 19:50:59 GMT
don't want to put a downer on your plan but if your going to have this done by a garage / company then the cost will soon outweigh the fun , ive done many car builds from chassis up to body swaps and there so time consuming its unreal , best advice id give you is if you have a friend or group of petrol heads and one or more can weld / fabricate then do it that way so you can do alot of the donkey work and lend others a hand in return ......just my thoughts , unless you have a bottomless cash supply ....LOL.
79 Escort Van (Cossie Turbo'd) 70 MK1 Escort Wagon (Weld-a-thon) 88 Saff Cosworth (2WD) 54 Ford Pop (V8) 29 Ford A Pickup (V8 Project)
Aug 16, 2013 21:05:34 GMT
also.... it would cost the earth to be LEGALLY on the road...
modified monocoque and all that jazz. Basically a cut'n shut
Aug 16, 2013 22:48:55 GMT
considered an electric power steering conversion instead? There are kits out there, do some googling
if you want old looks and modern mechanicals and have the cash to pay for that sort of work have a look at some modern kit cars.
79cord
Aug 17, 2013 10:16:54 GMT
Yep legally with such radical changes it often becomes a new car with all the additional requirements that entails. I remember the thread of Nissan Skyline floorpan under Datsun 120y/Sunny body. A few on here have also been heading the way of MX-5 engine/box in Herald
Aug 17, 2013 12:50:16 GMT
Thanks guys, going by the advice, I think its best to just restore the herald and make upgrades such as PS. Just have to now find someone with reasonable rates to restore the body. Rear deck in bad state and with no available panels in production, so I will have you find someone who can make the pieces required. Will post some pictures today.
Aug 17, 2013 13:06:14 GMT
A TVR donor might be an idea, still a lot of work. Although its backbone chassis should avoid IVA. Triumph Herald Speed Six has a nice sound to it.
Click picture for more
Aug 17, 2013 16:53:02 GMT
Yeah, if you can find a donor with a separate chassis with the same wheelbase, such as a Reliant Scimitar and then don't alter the chassis it will be classed as a re-body and not need tested.
Hi There was a classic car restorer based in wales which fitted a early 70s datsun body unto a modern car platform, (think it may have been a mx5 with the body cut off) can't find his detail anywhere. I have a 70 triumph herald in a bad state and toying with the idea of fitting the top half onto a modern floor. Mainly for reliability and for mods such as PS etc as car is for my father who suffers from arthritis. Can anyone recommend a garage who can undertake this kind of project/who has done similar projects in the past and who's rates are reasonable. Regards Razi I think this garage is a serial offender I heard of a cut down Mk6 transit with a Mk1 body.
A TVR donor might be an idea, still a lot of work. Although its backbone chassis should avoid IVA. Triumph Herald Speed Six has a nice sound to it. Oh this is relevant to my interest! ... What TVR Chassis is that?
The problem with TVR chassis is you can't cut the outriggers and they're mega wide, so unless you want a widened body or a stock car replica you're still stuck with IVA.
So how does the Golf bodied Beetle we all saw at the weekend make itself legal?
So how does the Golf bodied Beetle we all saw at the weekend make itself legal? Beetle floorpan = chassis = rebody = no IVA
Aug 19, 2013 11:45:49 GMT
So how does the Golf bodied Beetle we all saw at the weekend make itself legal? Beetle floorpan = chassis = rebody = no IVA Yeah, because a Beetle is separate chassis, the body itself carries zero points in terms of identity. Presumably would be enough original running gear that it got to keep its Beetle identity, hence being on a (IIRC) '71 J reg numberplate. You'd still have to declare the body swap and probably need a brief inspection to confirm identity though.
Aug 19, 2013 13:18:56 GMT
You'd also have to alter the make and model name, so if you do a DVLA check on it and it's still listed as a Beetle it's not registered legally
Aug 19, 2013 14:04:25 GMT
What about using a backbone chassis and running gear from a Lotus Elite, Excel or Éclat ? If you look they can be found for quite reasonable amounts.
Paul H
Aug 19, 2013 15:04:46 GMT
Thanks guys, going by the advice, I think its best to just restore the herald and make upgrades such as PS. Just have to now find someone with reasonable rates to restore the body. Rear deck in bad state and with no available panels in production, so I will have you find someone who can make the pieces required. Will post some pictures today. If you're going to pay a garage a (large) wedge of money to restore it, surely it'd be more cost effective to just buy a decent one to begin with? Heralds aren't that expensive and you'd get one in good shape for far less than you'd pay for someone to restore yours. I'm assuming that other areas like footwells, sills, bulkhead, door bottoms will also need work, if the boot floor is rotten. If all it needs is a few patches, then that's a different story. If that particular Herald has sentimental value, then that's a different story again!
Aug 19, 2013 15:13:40 GMT
You'd also have to alter the make and model name, so if you do a DVLA check on it and it's still listed as a Beetle it's not registered legally Indeed and they told me what the acronym that is now its make and model means, sadly it wont get through the swear filter
randywanger_
Nissan Bluebird P510 SSS Coupe
Aug 19, 2013 15:41:43 GMT
Oh this is relevant to my interest! ... What TVR Chassis is that? TVR Griffith chassis, Think TopGear used one to make their electric 'car' from.
