Hi lads
I was wondering if anyone can give me some pointers as to what's needed to fit a Type E(Rocket) box in a Mk1 Escort with a tiny,standard gearbox tunnel.
First of all do I use the standard gearbox crossmember or is the 1300 box one different to the Type E crossmember?
I've had the box on a trolley jack and offered it up but the gearlever housing(removed the lever) hits the box section(just behind the original gearlever hole.) in the tunnel long before the mounting bolts even come close. I know the bellhousing will require some mods to fit as well
Is it worth buying a big gearbox tunnel from the likes of GRP4 Fabrications or Peter LLoyd Rallying?
I'm trying to move away from my previous life as an innate bodger so I'd like as neat a solution as possible.
Googled it a lot but can't seem to find anything concrete to go on!
Thanks in advance for your help
Tom
Tom
