Well worn and sadly the tape deck refuses to work. It powers up and makes some noise, but I could see no evidence of the tape reel moving.
Good news is that it has a 3.5mm jack input so you can connect whatever you like to it via this.
The amplifier works perfectly, pack around 5.5 watts rms per channel. I have tested it and it is loud, my guess is that the 5.5watts is a pretty conservative figure.
The tape deck has a din socket on the rear to allow connection of a tuner. Unfortunately I don't have the tuner part.
Cosmetic condition, I would describe as well worn! The whole tape unit is aluminium plated, there are ares where it has worn away aswell as some green marks caused by corrosion. The knobs and buttons are all solid metal as far as I can tell. The amp is in better cosmetic condition, with just some light scratches here and there.
£30 collected from either chipping norton, oxford airport or rr gathering
£38 posted
