I'm looking to get hold of a small rear axle. its for a go cart. I`d like to get one that is a real axle, think Volvo axle ie real diff, propshaft flange etc etc. but needs to be small sort of half/one third scale in comparison to a Volvo. I know its possible to cut down a reliant axle but it would be to heavy and the mechanical drag wouldn't be good. so my question is does any one know of anything that has/had such a thing fitted. want to make a front engine rear drive buggy for my boy, can do all the fab work and propshaft etc, just having trouble finding a suitable axle. any help would be great. cheers.
Toyota mk3 supra. retro goodness.
Reliant axles are quite light so doubt you'll find any car item that weighs less. What about ride on mower axle ? What engine are you planning on using ? ie is it shaft or chain drive etc.
Paul h
Reliant axles are quite light so doubt you'll find any car item that weighs less. What about ride on mower axle ? What engine are you planning on using ? ie is it shaft or chain drive etc. Paul h ride on mower axles are generally belt drive to a pulley on the top, really want a real but small axle. I realise that I wont find a smaller car axle than a reliant, I was wondering if any one knew of some weird or obscure piece of machinery that had one on. engine wise I`ll use a single cylinder engine with centrafugal clutch.
Reliant axles are quite light so doubt you'll find any car item that weighs less. What about ride on mower axle ? What engine are you planning on using ? ie is it shaft or chain drive etc. Paul h ride on mower axles are generally belt drive to a pulley on the top, really want a real but small axle. I realise that I wont find a smaller car axle than a reliant, I was wondering if any one knew of some weird or obscure piece of machinery that had one on. engine wise I`ll use a single cylinder engine with centrafugal clutch. Why not turn a mower axle 90 degrees so the pulley is on the side and facing forward ? Paul H
How about something out of a Bedford Rascal or its Suzuki equivalent. Think small Japanese van and see what they have. Or even a Suzuki Jimny.
Adrian
Vitesse 6 Saloon Vitesse Mk2 Convertible BMW R1150GS VW Amarok
I've got a spare axle for a KP Starlet if that's any use? Still not THAT small though, about 4' iirc
Have a look for gearboxes made by Exeeco. They are industrial gearboxes made for slow speed use, but built like brick outhouses. They are megabucks new but peanuts used as they are quite specialist and supplied to order. You want the IB range, not IS. B stands for bevel followed by a number which is the 1:number ratio. You'd have to fashion your own input/output shafts but they have standard industry flange connections.
Otherwise, how about shaft drive bikes - Old BMWs, Honda CX500 or even 80's honda scooters as they have cvt gearboxes and bevel gearboxes in one.
'83 GTM Coupe. 4A-GE Powered '00 GTM Libra Auto. Ick. '71 Detomaso Pantera. Current Resto '89 GMC Safari Tow/Kip bus '05 SAAB 9-3 Daily '71 Siva Moonbug. Not even contemplating resto yet.
What about building an axle ? You can get the components from off road buggy parts suppliers. The diff commonly used a Comet SCD 1 item but there are others avialable. Only problem is it's chain drive and not shaft. For example - www.northerntool.com/shop/tools/product_35768_35768Paul H
bortaf
Golf cart ?
R.I.P photobucket
What do the 4x4 quads use? there must be a transfer box and diff in there.
sweaty palms slip off joystick
What do the 4x4 quads use? there must be a transfer box and diff in there. I believe most of them use solid rear axles, ie. no differential. Most of the ones which do have diffs use half shafts and wishbones, ie. no solid live axle housing. However, you're right that some do have live rear axles in them. Unfortunately, I think this style of quad axle is too new and too rare to be cheap enough for a home-built go-kart.
