rob963
Club RR Member Number: 97
'93 Citroen BX17 TZD Estaterob963
@rob963
Club Retro Rides Member 97
Jul 18, 2013 23:29:59 GMT
So, my second car in as many years. first came the Mini (Classic), and now this, almost the complete opposite. This car was bought from Mystery Machine without actually driving it. Then had to wait another week (almost) and then threw myself in at the deep end by changing the timing belt and the water pump. which took a whole weekend. the above replaced this: there also had to be some welding and a new 'zorst (courtesy of Rich) Welding: 'Zorsting: yes the tip is blue, and straight. Because I ruined the original down turn, with my less-than-useful angle grinder skills... Then came the MOT which threw this up: oh dear... somehow missed that when going over the car but it soon became this (by soon, I mean 3 days later): only just realised it is blurry, but you get the idea... also needed a new front number plate, which is a shame as the ones on there when I bought it were the originals also changed the alternator belt (in the same condition as the timing belt and was very schreechy) and made the front washer jet work (blocked). I think that's it for now, and this thread will probably just be me keeping track of what I end up doing to the car. I will admit that I am unlikely to make many drastic changes to the car as it has been bought to act as a vaguely interesting and reliable daily. thanks for reading so far, Rob
Last Edit: Jul 18, 2013 23:35:21 GMT by rob963
Rich
Club RR Member Number: 160
'93 Citroen BX17 TZD EstateRich
@foxmcintyre
Club Retro Rides Member 160
Subscribed, obviously. That sill was quite a challenge then by the looks of it. Sorry to hear it was hiding more grot than we thought but at least that is all taken care of now
rob963
@rob963
Subscribed, obviously. That sill was quite a challenge then by the looks of it. Sorry to hear it was hiding more grot than we thought but at least that is all taken care of now Yeah it was quite a shocker when we started poking, but it's all good, sorted and legal now
MrOtter
West Midlands
"Your car is your story, so don't let someone else write the book." - Moog
Jul 19, 2013 16:54:27 GMT
Now I'm nervous about the bubbling on the rear of my sill! Might have to give it a little tap with the hammer when I get round to de-rusting my rear end. Looking forward to seeing the progress! Bookmarked
rob963
@rob963
Jul 19, 2013 20:31:36 GMT
Now I'm nervous about the bubbling on the rear of my sill! Might have to give it a little tap with the hammer when I get round to de-rusting my rear end. Looking forward to seeing the progress! Bookmarked Haha when I saw and poked it crumbled instantly. I think if you have already had a good poke around you should be okay (touch wood) I have taken some pictures when doing the timing belt/ water pump, but they may or may not be of any use to you when you come to doing yours...
rob963
@rob963
Oct 10, 2013 21:15:39 GMT
so last night this happened: took two hours to get that flipping pedal box out of the car. And managed to break the clutch cable in the process as the nuts were practically welded on with rust. which meant the end snapped off whilst I was trying to undo it to give the cable some slack. so now I'm waiting for a new one. still in the mean time, the pedal box had this done to it: the steel is roughly 3 times thicker than Citroen deemed necessary to install originally. hopefully it should suffice for now and if not, I have a plan to strengthen it properly. It'll get a good coat of paint before it goes back in. which could be some while as I have had to order one in because no one nearby had one. fun times...
Oct 12, 2013 18:48:57 GMT
I had a tzd about 10 years ago and the pedal went on that one
rob963
@rob963
Oct 12, 2013 19:00:23 GMT
I had a tzd about 10 years ago and the pedal went on that one Yeah it is a common problem... Mainly due to a earth shatteringly pathetic design of the bracket by Citroen.
jomfun
Oct 12, 2013 20:27:54 GMT
Need some obligatory up and down pics asap!
rob963
@rob963
Oct 12, 2013 20:49:58 GMT
Need some obligatory up and down pics asap! As soon as it's all back together, I'll get some and put them on [could be a while, I'm waiting on a clutch cable ]
rob963
@rob963
Nov 19, 2013 11:08:50 GMT
So the clutch cable has been done for a while (and took most of 2 days to fit ) no pics of that as I just wanted to get it done and out of the way. as promised, uppy/downy pics: Up: Middle: Down: yes I realise there is a wheel trim missing, I think when I had new tyres fitted the monkey who did it must have broken it. didn't realise it at the time and then it was gone other than that, there have been a few (read many) LHM leaks, mostly caused by old rubber and probably me being too rough when trying to fix them and pulling more pipes out and it needs front wishbone bushes. And rear arm bearings. yay. that's all for now, Rob
Nov 19, 2013 15:08:38 GMT
Can these be driven on the lowest setting or with nose in the air?
Was offered one many years ago but had know where to keep it!!
Nov 19, 2013 17:29:47 GMT
Rear arm bearings are relatively easy on these. I've done 6 or so. If you buy a bearing kit you get a new axle bolt. Make a drift out of the old bolt, works perfectly for removing those stubborn old races. Lots of hammering gets them free.
Vauxhall Omega V6 Estate
Landrover Defender 300Tdi
Ford Puma (winter smoker)
rob963
@rob963
Nov 19, 2013 23:01:16 GMT
Can these be driven on the lowest setting or with nose in the air? Was offered one many years ago but had know where to keep it!! They can technically be driven on the lowest setting, but at that point there is no suspension as the thing is sat on the bump stops and has no damping making it very bouncy. (I forgot to put it up before driving it once ) as to having just the nose in the air, not as standard, but you could probably mess around with the height adjustment to raise the front up in 'normal' mode Rear arm bearings are relatively easy on these. I've done 6 or so. If you buy a bearing kit you get a new axle bolt. Make a drift out of the old bolt, works perfectly for removing those stubborn old races. Lots of hammering gets them free. Thanks for the tip! I'll make sure to follow it when I do them (fairly soon hopefully!)
Rich
@foxmcintyre
Nov 19, 2013 23:19:27 GMT
Can these be driven on the lowest setting or with nose in the air? Was offered one many years ago but had know where to keep it!! You would have to separate the height control rods onto 2 lever as opposed to the one which is linked front to back. Would be fairly easy to do in all honesty. But you wouldn't drive it de-pressurised for long before you trashed it totally. You can however run it slightly off the deck and put a little juice in the spheres by putting the lever just off of de-pressurise. Gives it enough to lift off the stops.
rob963
@rob963
Nov 20, 2013 20:32:33 GMT
Another day, Another leak. Got in the car this morning and was confronted by this all-too-familiar sight: damn that's blurry but the top oval light says 'STOP!' and the one on the left says '(!)' and the other one is just to say the parking brake is on. oh yay, low LHM. so had a poke around underneath and found this: yummy! I didn't have any inner part handy to connect the two with, but having a look around, I happened to have a couple of these lying around: the connections seemed to be about the right size, so I took the innards out (didn't want any complications) and filed off the barbs (didn't want to over stretch the ancient pipe) and bingo!: I thought that was that, until I had to move it and change the coolant (needed to have at least some antifreeze in there...) at which point I found this: that's green. oh bum. turned out it was a return pipe from the rear which was leaking. no photos (kind of hard to photograph anyhow) but managed to fix it finally. sigh. another leak down, soon I will have gone round the whole car. oh well. 'til next time. Rob
Rich
@foxmcintyre
Nov 20, 2013 20:56:32 GMT
You really need to replace those front strut returns, that's twice they have been bodged now
Nov 20, 2013 22:01:54 GMT
That slick at TAB was a bit impressive.
Rich
@foxmcintyre
Nov 20, 2013 22:58:07 GMT
That slick at TAB was a bit impressive. It was rather. Never seen so much LHM fall out of anything ever!
rob963
@rob963
Nov 20, 2013 23:01:08 GMT
You really need to replace those front strut returns, that's twice they have been bodged now I know, time/money are things which are rarely in my possession at the moment That slick at TAB was a bit impressive. Haha so I have heard, I haven't seen it though
