edwell
My (non GTi) 205 has recently become a bit "wobbly", It looks like the anti roll bar bush in the middle of the track control arm is knackered. My question is can the bush be replaced or is it a whole new arm? I did a quick search but anti roll bar bush only returned the "inner" bushes, however there is a TCA outer bush listed, Is this what I need? outer bushits the bush in the middle of the arm that has gone.
before you go replacing the bush, check the balljoint, as you'll need a complete arm if there's play in that.
If they are like Capris and old Escorts the outer bushes can wear badly. It could be balljoints, although these will tend to knock/chatter more.
edwell
Jul 10, 2013 14:02:11 GMT
I have ordered a complete arm, I found one for not much more than the bushes, and I was in a rush because I'm supposed to be doing a 400 mile round trip at the weekend. I will report back once it is fitted
