hi all, ive decided to take the plung proper into a retro car with (hopefully) an early
mgb sebring type replica (maybe not the wide arches??) with some sort of ford 16v throttle body conversion.
I'm not exactly 'green' when it comes to old cars having owner a few pugs in my time (ph1 306 cab, ph1 xs1 cab, ph1 205 gti6 and currently a ph1.5 205 gti with an xu7 engine in it) but to be honest I know nothing about ford engines which is the plan going forward with this poject.
my current 205 project can be found over on the 205 drivers forum: forum.205gtidrivers.com/index.php?showtopic=130168
this is hiow she stands at the mo: basically I promised the wife that when the 205 was finished she could choose the next car to 'play' with.
she has decided (well with a little help from me) on an mgb gt but brought into the 21st century.
I've been toying with different engines including k series, t series, bmw etc, but I think I'm settled on a zetec/duratec with either a mt75 or type 9 box.
now I don't really know too much about ford engines, ideally I would like a duratec st engine but am concerned about the vvt and dmf setup so a basic silvertop of blacktop would be the sensible option? 2.0ltr would be the size.
can anyone give me any actual facts and advice on what's best to go for engine wise? id like to keep the spend down but by no means be a cheap skate with it, will be running tb's and some sort of aftermarket management.
I don't mind doing some head work as I quite enjoyed that on the xu7 so would need to be an alloy head (are they all?)
so strongish bottom end and a decent head (not really fancying the st170 head and vvt setup)
best one for parts and interchangability across the ford range along with mating to a rwd box.
so far I have got silvertop 2.0 engine and fly, pinto clutch and type 9 box. more than likely emerald or omex management......
also is there a section for pojects on this forum?
cheers
pete
cheers
pete
