Violet Vivid
Reports of my demise were somewhat exaggerated
Jun 21, 2013 12:25:16 GMT
Heya all!
I'm trying to find a beefier electric fan for my Land Rover, does anybody know what cars/vans had the strongest ones going for 12v? Aiming up to 14" single diameter, though may go bigger
xXx
Violet, purple-loving Landy obsessed Purple-haired CyberPunk Almost model & occasional word wrangler regarding Landies xXxIf she can't decide on what kind of genitalia she likes to play with you're better off without her. Move on... play with Land-Rovers.
Jun 21, 2013 12:29:54 GMT
I'd simply fit a standard mechanical fan to the waterpump. Never had a problem with any of my Land Rover overheating.
Paul H
Jun 21, 2013 12:45:32 GMT
I've a passat one in my shed it's about 13" and it's very powerful ;-)
Copey
Jun 21, 2013 13:41:59 GMT
got a focus C-max one in the Capri, really powerful!
Electric Fans - Strongest?stealthstylz
@stealthstylz
Club Retro Rides Member 174
Jun 21, 2013 14:52:21 GMT
PM blackpopracing on here or look through his build thread, he used a Volvo or similar one they're pretty mental.
Electric Fans - Strongest?ChasR
@chasr
Club Retro Rides Member 170
Jun 21, 2013 19:50:57 GMT
When exactly does your LR overheat?.
The Kenlowe on the Stag with the recon rad keeps it cool for pretty much every situation. On the old silted rad (which looked fine outside) it would struggle to keep it cool enough in traffic and travelling over 50MPH down a motorway was a big no no.
Violet Vivid
Jun 22, 2013 20:49:42 GMT
have emptied the 'coolant' (was mostly water) out of her today, replaced by quite strong mix antifreeze. Also rrtried fitting a standard series fan, but with this one having the later 2.5 n/a diesel the bolt holes on the pump & pulley don't fit.
This is in my 882, she seems to be getting Very warm on runs, even without a thermostat. the waterpump appears to be work as it froths the water in the rad up lol
Also this is my current fan:
xXx
Jun 22, 2013 22:30:36 GMT
As a rule the old landy engines will run cooler due to the mechanical fan. What lump do you have in there? P.S. ran a landrover workshop for around 10 years and have had about a dozen myself ;-)
'88 Cadillac Brougham hearse (white) '91 Carlton GSi 24v '72 Dodge dual cab pick up '99 Mercedes S55 AMG
Violet Vivid
Jun 22, 2013 23:16:28 GMT
Ahh cool mine's got the 2.5n/a out of a ex-MOD 90 in it
xXx
Jun 23, 2013 10:04:26 GMT
The Kenlowe on the Stag with the recon rad keeps it cool for just about each scenario. On the previous silted rad (which looked fine outside) it might struggle to stay it cool enough in traffic ------------------ 2013 MERCEDES BENZ SL-CLASS
Jun 23, 2013 14:31:36 GMT
As its a N/A and it runs hot without thermostat then it might be worth seeing if the head gasket has failed. If its not getting that hot , then look at the temp sender being up the swanny, if you know someone with a non contact thermometer , borrow that and see what the temp of the rad is when warm and also the heater hoses as this will give you a better idea of the actual temp of the engine and indicate if there is a restriction in the water flow and if the temp sender is the challenge.
@chasr
Jun 23, 2013 22:47:50 GMT
Are you going to the FUCEM meet in a couple of weeks time Violet? I may come along and bring my temp gun along (an IR gun which measures temperature wherever you point it(I bought it when I got the Stag . Failing that, the guns are cheap on ebay (I paid around £14 posted for mine, and have used it for many other things (for cars with tubular manifolds, it is great for seeing what cylinder is the problem).
You might consider getting smaller fans and going to a twin fan set up? You cover more of the rad thataway.
Although have to agree that with a mechanical fan you'd be hard pressed to overheat a n/a lump.
xXx Err stupid question time ...(no offence) but is the fan in the right place? Some are for mounting in front of rad, others for engine bay side, so you end up with airflow going wrong way ......
Jun 24, 2013 12:08:20 GMT
A pull fan with a shroud will be far better than that thing just slapped in the middle of the radiator. No matter how strong it is it's only moving air over a tiny area at the moment.
