Mike
East Midlands
Jun 15, 2013 20:45:38 GMT
I'm breaking a 1989 Phase 1.5 Peugeot 205 GR for some parts, but I thought I'd see if anyone needs any parts off it before I scrap the shell. I've already removed the suspension and I want the engine and box, but apart from that the rest is going. Anyone need anything? It'll be here for another 3 weeks I think before I scrap it. EDIT: location added to title seeing as the new forum doesn't display it under your name any more...
Last Edit: Jun 26, 2013 15:51:16 GMT by Mike
Carlos
Jun 16, 2013 20:54:22 GMT
What sort of condition are the rear seat base mounting brackets in (the one's that bolt to the floor pan)? Same with the front seat belt lower mounting points? If they're not rusty I'd be interested in them, and possibly a few other odds and sods.
Cheers
Carl -------------------------------- 1992 Peugeot 205 GTi 2.0 16v 2004 Volvo V50 T5 --------------------------------
Mike
East Midlands
Jun 16, 2013 22:21:45 GMT
I'll have a check tomorrow for you.
niwid
Jun 17, 2013 14:59:44 GMT
I'm after decent nick base spec seats, what are your like? Do you have pictures?
bnptrs
Jun 17, 2013 15:02:47 GMT
What condition are the amber front indicator lenses in? would be interested in these for my 205.
Jun 17, 2013 15:55:34 GMT
Only a small part, but I need the small bracket that the drivers side front seatbelt buckle bolts up to. I can get a picture if needs be, but it's sort of L-shaped and sandwiched between the seat subframe and the carpet near the handbrake. You'll need to under the bolt attaching the seatbelt buckle, and the T40 torx bolts that secure the subframe to the shell to remove it. I could also do with part of the boot floor if you would be willing to cut that out and send it, assuming of course that it's not rusty or bent from previous accident damage. Otherwise, what model / age / spec is it, as I can't tell beyond it being a lowish spec pre-1991 model? There's probably a few other small bits I could do with - I'll have a think
Last Edit: Jun 17, 2013 15:56:00 GMT by Anthony
1990 Peugeot 205 GTi 1.9 // 1991 Peugeot 205 GTi 1.9 16v // 1992 Peugeot 205 GTi 1.9 // 1999 Peugeot 306 Meridian HDi Estate
Jun 17, 2013 19:22:05 GMT
Off side rear door ( drivers side ), any chance , mines pretty well mullered after the lock mechanism seized .
dave
Mike
East Midlands
Jun 17, 2013 20:58:22 GMT
What sort of condition are the rear seat base mounting brackets in (the one's that bolt to the floor pan)? Same with the front seat belt lower mounting points? If they're not rusty I'd be interested in them, and possibly a few other odds and sods. Cheers I'll pop up a photo, they have a bit of surface rust. I'm after decent nick base spec seats, what are your like? Do you have pictures? Pics soon, they aren't bad. What condition are the amber front indicator lenses in? would be interested in these for my 205. Tiny chip in the N/S, I'll put up a photo. Only a small part, but I need the small bracket that the drivers side front seatbelt buckle bolts up to. I can get a picture if needs be, but it's sort of L-shaped and sandwiched between the seat subframe and the carpet near the handbrake. You'll need to under the bolt attaching the seatbelt buckle, and the T40 torx bolts that secure the subframe to the shell to remove it. I could also do with part of the boot floor if you would be willing to cut that out and send it, assuming of course that it's not rusty or bent from previous accident damage. Otherwise, what model / age / spec is it, as I can't tell beyond it being a lowish spec pre-1991 model? There's probably a few other small bits I could do with - I'll have a think Found the bracket you mean, this bit? And yeah, I should be able to cut some of the boot floor out for you I think.
Mike
East Midlands
Jun 17, 2013 21:02:06 GMT
Photos! Teeny indicator chip, they are good apart from this. Front seatbelt mount (is this the bit you meant?) Rear seat brackets: Seats - all look like this. Oh, and it's a 1990 1.4 GR, non-sunroof, manual everything, grey interior.
Last Edit: Jun 17, 2013 21:03:38 GMT by Mike
bnptrs
Jun 17, 2013 21:09:30 GMT
Fine to me - what are you looking for them?
Mike
East Midlands
Jun 17, 2013 21:16:05 GMT
Off side rear door ( drivers side ), any chance , mines pretty well mullered after the lock mechanism seized . dave This door is good as far as I can see. Doesn't open at the mo so can't check properly... £20 if it turns out to be rust free?
Carlos
Jun 17, 2013 21:36:12 GMT
What sort of condition are the rear seat base mounting brackets in (the one's that bolt to the floor pan)? Same with the front seat belt lower mounting points? If they're not rusty I'd be interested in them, and possibly a few other odds and sods. Cheers I'll pop up a photo, they have a bit of surface rust. No better than mine, so don't worry mate. I was just trying to get out of cleaning mine up and repainting
niwid
PM'd
If you can get the door open without wrecking the door lock bits fine I can make it Saturday afternoon. to collect Call me on 07729615009
Mike
East Midlands
Jun 18, 2013 21:13:25 GMT
Fine to me - what are you looking for them? £5 plus postage mate.
Mike
East Midlands
Jun 18, 2013 21:14:27 GMT
If you can get the door open without wrecking the door lock bits fine I can make it Saturday afternoon. to collect Call me on 07729615009 I'll try and remove it this week, can't do Sat PM tho, sorry. PM me to sort out a suitable time if you want.
I can do Monday , Tuesday or Wednesday ,next week, after that back to work
kenb
Don't suppose it was a power steering model was it? still looking for a lower column ie the bit that attaches to the rack, must be from a PS model though.
Jun 19, 2013 12:37:44 GMT
Mike, sounds daft really but not sure what yu mean by PM. means phone me ? if so I do not know your number or where to go to collect . Still want the door.
Mike
East Midlands
Mike, sounds daft really but not sure what yu mean by PM. means phone me ? if so I do not know your number or where to go to collect . Still want the door. Hey, it means Private Message, click on my username and you'll be able to send me a message. Saves clogging up the thread with our arrangements.
