blaupuntk md 1690 2 way co-ax speakers
90 watts max
45 watts rms
13cm dia midrange cone
40mm approx tweeter
plastic casing measures approx 18cmx18cm
55mm mounting depth needed
4 ohm impedance
adjustable tweeter position
made in west germany, so good quality
Designed to be shelf mounted and do require a hole to be made to allow clearance for the magnet
Not sure on their age, but I guess they date from around the lates 80s to early 90s going on the made in west germany label (probably more towards being 80s, seing as the berlin wall was all but flattened by 1990). I have completely stripped them down, cleaned them, re-coloured the speaker cones black, as they had faded and re-painted the grilles. They don't look far off being like new! There are a couple of light marks to the plastic housings and some tiny little dents to the speaker grilles (so small they won't show up in the pictures)
The speakers are in full working order, no damage other than the faded colour, which has been rectified. The tweeters are paper cone type and still function as they should, the main woofer cones are in good order, the have fabric suspension, rather than foam or paper, so have suffered no deterioration.
They sound great and they look great! Just need a nice classic from the 80s or 90s to fit them in!
£35 posted
£30 collected from chipping norton or oxford airport
90 watts max
45 watts rms
40mm approx tweeter
4 ohm impedance
£35 posted
