Here are parts left over from my Volvo 360 Turbo, P11 Primera, spares from my Escort RS1600i, and a few performance/upgraded parts I have no use for.
All parts are plus postage (I can arrange cheap courier transport if needed). Collection from Sunderland/Durham/Newcastle is welcomed.
Wobble nuts x32. M12 x 1.25.
Some with damaged thread, but easily enough for a good complete set £20
Land Rover 90 front dampers. As fitted to the rear of the Volvo. Covered maybe 5K miles.
£10
Forge BOV with Samco joiner and T-piece.
£30
Horn pushes and gear knobs
£5 each
Nissan Primera P11-144 O/S/R fog lamp and seal. NOS genuine. £10
Nissan Primera P11e/P11-144 front windscreen side and top mouldings. NOS genuine. £20
Rover MGF rear view mirror (identical to Primera mirror, but has two switchable lights in base). £5
0 gauge amplifier power cable and fuse, blue. Approx 4-5 metres (will check). Very light use. £15
Mk2 Ford Grandad chassis leg (tow eye) repair section. NOS. £10
Other Volvo 300 series parts
Chrome trims for F&R bumpers x2 sets
343 quarterlight front doors. Repaired. 90% rust free
VGC tailgate
Mk1/2 tail lights, headlights, indicators
GLT grille
Smiths instrument cluster (8K RPM) and speedo cable
Indicator and wiper stalks
Glass, parcel shelf, carpets, headlining, screen surrounds, badges etc
Mk2 bumper bolt caps
343 window regulators x4
Volvo floor trays
360 wiper linkage
360 engine bay undertrays/bonnet hinge cover
GLT fuel pump
Chrome aerials x2 (one with cable) Black mk3 aerial
Bumper trumpets
Lower arms
Tie rods
360 driveshafts
Early anti-roll bar
343 door mirrors x4
Door handles x4
343 rear quarter 'vent' trim x2
GLT fog lamp
3dr weather strips and seals
343 front door seals, runners etc
360 GLS bump exterior bump strips, inc boot.
343 front door bump strips x2
Early 360 GLT front bump strips x2
343 door exterior window frame trims black x2 chrome x2
Front and rear washer bottles, inc washer jets. Header tank
B19 clutch cable
B200K (I think) acclerator cable
360 servo and master cylinder
Front shock inserts (low mileage) x4
360 GLS centre caps
Boot struts
Headlight wiper motor inc arms x2
Lots of bags of OE fasteners, tank strap bolts etc
Mk3/4 Escort parts(Still need to properly sort through these, but if I save this in Notepad, it breaks all of the links and paragraphs...)
RS1600i front spot lamps. Non-genuine, again basically new. Only marks are from being clamped by the brackets.
£40
RS1600i front fog lamps non-gen. Basically new (only marks are where they have been attached to mounting brackets) Come with brackets (non-gen)
£30
Both were fitted to my car when I bought it. No stone chips/cracks/signs of use on either.
Mk3 front speaker pods, complete
mk3 battery cover w/lines. NOS
mk3 rear washer bottle & pump & grommet
S1 RST handbrake surround & brackets
mk3 front grille w/light blue badge
mk3 front grille, broken lower tab
Track control arm, complete. NOS
RS1600i rear gearbox mount, slight split, complete
RS1600i front gearbox mount, rubber NG, bracket OK
mk3 front suspension top mounts, late
mk3 indicator stalk x2
mk3/4 sunroof deflector w/seal
(Fiesta?) gearbox mount, square, NOS
mk3 rear ARB, powder coated blue
mk3 front dampers, black, blown, (Koni?)
mk3 centre console
RS1600i headrest
mk4 header tank, red cap
mk3 sunvisors x2
mk3 glovebox door (RS/Ghia)
mk4 front speaker cover
mk3 internal tailgate covers (one plastic,3 card)
mk3 door mirrors, pair, painted
mk4 door mirror
mk3 steering shrouds, upper and lower, several
Black window winder
Battery cover, flat, slightly twisted
Instrument cluster surround x2
Front washer bottle, small (mk4)
Front seatbelt stalks and runners
RS1600i front ashtray x2
RS1600i/S1 RST seat winders, covers, flip handles etc
mk4 HRW loom
RAd hose gen
mk3 bonnet cable
mk3 N/S/R liight(made in England)
mk3 rear view mirror x2
mk3 heater controls and surround
mk3 boot struts x2
mk3 wiper stalk x2
RS1600i washer bottle bracket
mk3 instrument cluster, rev counter needle broken
Interior door handle surrounds x4
mk4 outer door handles, plastic
mk3 grab handles x4
mk3 earth strap, interior
mk3 interior mirror covers x3, broken pegs
mk3 washer pumps x2
mk4? washer pump x1
mk3 heater blower ducting
mk3 centre console pocket/insert, w/speaker fade control joystick
NOS genuine bracket, check what it is
mk3 B pillar trims, pair
mk3 centre console and brackets
mk3 seatbelts x4 (all front, early & late?)
mk3 gear gaitor, one broken peg
mk3 headlights and indicators, check box contents
Reply on this thread or PM me if you require further info or pictures etc. I will return to update and sort this out.
Cheers, Liam.
£10
£30
£5 each
VGC tailgate
GLT grille
Volvo floor trays
360 wiper linkage
GLT fuel pump
Bumper trumpets
Lower arms
Tie rods
360 driveshafts
Early anti-roll bar
343 door mirrors x4
Door handles x4
GLT fog lamp
B19 clutch cable
360 GLS centre caps
Boot struts
£40
£30
mk3 centre console
RS1600i headrest
mk3 sunvisors x2
mk4 door mirror
Black window winder
mk4 HRW loom
RAd hose gen
mk3 bonnet cable
mk3 boot struts x2
mk3 wiper stalk x2
mk3 grab handles x4
mk3 washer pumps x2
mk4? washer pump x1
Cheers, Liam.
