g40jon
May 21, 2013 20:15:37 GMT
blaupunkt acr3231 radio cassette player, A really nice retro stereo! very minimalist, so not many buttons or functions. It is in good condition, however there is one cosmetic defect on the top left near the blaupunkt logo. The radio works fine, as does every other function that I have been able to test, the tape deck will be tested tomorrow, now that I have located my old tapes. This would be a perfect OEM addition for any classic 80s or early 90s motor. 2x6.5 watt rms speaker outputs Tone control fm/am/lw radio tuner No code required fitting cage included Print out of user manual also supplied Collection welcome, try before you buy also welcome If posted, the unit will be sent via UPS, so is fully trackable. £30 posted £20 collected from chipping norton or oxford airport
Last Edit: May 23, 2013 7:42:25 GMT by g40jon
May 21, 2013 21:17:48 GMT
Got any pics from behind? And of the defect a bit closer? Cheers, Matt
g40jon
May 21, 2013 21:39:58 GMT
will get some more pics done tomorrow. the rear has two iso plugs, one for the power and the other is for the two speaker outputs. the third bigger iso is redundant, as there are no pins on it. I will take a macro shot of the defect. it looks like the corner has been exposed to heat, as the plastic has bubbled. No idea how or why. No damage to the wiring or circuit board though. (I had the case open to replace the backlighting lamps which had blown)
Just to add the tape deck works perfectly and actually sounds very nice.
Last Edit: May 22, 2013 6:35:40 GMT by g40jon
May 22, 2013 10:49:11 GMT
okay great
g40jon
May 22, 2013 12:32:43 GMT
May 22, 2013 17:49:15 GMT
okay mate ill have that, pm me your paypal details
g40jon
May 22, 2013 18:02:27 GMT
pm coming your way.
