Need some help finding some shocks for my Fiat 127 which I have recently lowered.Its running on the standard shocks at the moment but could do with something with a shorter insert.Don't want to be spending loads and have seen some PI ones on ebay at reasonable prices so the plan is to try and find a shock off a different car with the same measurements.I had read that mk2 Golf ones would fit but the sizes are different.
So,my sizes are 48mm between the bolt hole centres and 26mm internal where it sits on to the hub.If anyone has some old shocks lying around that they could measure and I could try and find a match.
Thanks in advance.
Thanks in advance.
