Was going to use this on my polo but going a different route now. I have the ecu, loom, instructions and disks. There are no sensors but these are generic type sensors anyway so could be picked up cheap from scrap yards. Also no serial lead to connect to a lap top but these are curse word cheap on ebay
Couple of pics of it plugged into a pc
I can get pics of whats actually included later
It currently has a map on it for a vauxhall red top on itbs but this can be used as a base map for any setup
Looking for £300ono
Bit of official type info on it...
Suitable for 4-cylinder engines. Ford 36-1 teeth flywheel pattern or Bosch (Vauxhall) fitting 60-2 teeth. Distributorless ignition and semi-sequential fuel injection. Will interface directly to Ford or Vauxhall engines with flywheel pickup already on engine (eg Ford Zetec or Vauxhall 2.0 16v). Alternatively the crank wheel can be fitted to most engines.
Looking for £300ono
