My Dad is going to be selling his faithful Rangie, its on an 'X' which is 1980 ish from memory, all original though well used, body is solid with no rot in the usual places, top and bottom tailgate are good, HC 3.5 V8 with a genuine rover exchange 4 speed box and overdrive. Had an LPG conversion in the late 80's and has been on it ever since, been used daily but wants a bit of attention - gearbox has a leak and contaminates handbrake shoes, couple of bits of welding for the next test - out riggers from memory. Petrol tank leaks so it hasn't had petrol in it in over 2 years now, starts instantly on gas no matter how cold it is.
Mechanically its spot on and does about 16 to 18mpg on gas. Baring the gearbox leak i've driven it from one end of the country to the other previously and I'de happily do it again.
Full tow gear fitted. Interior is best described as well used - there are waterproof covers on the front 2 seats as they were the worst - I think it has the teddy bear trim but I could be wrong, Headlining is good - it should be its the 4th one its had - no sunroof. Its MOT'd but I think the tax will have to come off it.
Any idea what its worth? I'm frankly well out of touch, same owner for the last 15 years maybe more. Don't really want to ebay it so any suggestions of forums to put it on would be appreciated.
Cheers
Cheers
