done a deal with a local old boy to clear his barns/sheds/back garden. this is the first two vanloads.
F type victor bench seat. SOLD- another comming soon!
daily mirror 'best all along the line' railway advertising enamel sign. average condition, some corrosion but cleans up well. £60.
pop grille shell. good condition, some surface rust to bottom but solid. with splash panel. £85.
pop bonnet/sides. one small crack on one top corner, rest is good. £50.
pop inner wing. SOLD.
pop front wing- offside. reasonable nick, no damage to outer edge/lip swage, no dents, headlight mount perfect, needs the lower rear edge replacing and some work to the mounting flange, though not total replacement. includes wing brace (not shown) in good nick. £50
pair of austin somerset steel wheels- 16"x3.5" wide, ford 4x108 PCD. wheels good, tyres dead but do hold air for mockup purposes. £40.
1x pop 17" wheel in good nick, £20, 1x hillman minx steel wheel, 15" ford 4x108 pcd, £20.
a very unusual pair of wire wheels. no idea what they're from, but they're 19", and jag/chevy 5x4.75" PCD. good and straight with no major corrosion, but there is 2 or 3 broken spokes- they're normal straight-nipple motorbike style so easy to replace. £75.
datsun 620 pickup grille shell, no damage. £50.
an assortment of english ford steering wheels/columns/boxes.
sit up and beg pop, some cracking but no sections missing, with hornpush, column and bracket. £50.
100e with hornpush, column shroud, pittman arm. box operate smoothly, steering wheel reasonable nick. £60.
100e, no column shroud or hornpush, wheel a bit rougher but I don't think it has any real damage. £40.
105e, wheel is split and crappy, box is good though, £40.
pedal cars. BOTH SOLD.
update, pt.2-
raleigh tomahawk. needs work, 325.
F-type victor dash console. chrome has pitting but actually looks quite respectable. heater controls siezed but would free off. would make a cool custom dash. £25.
F-type victor switch binnacle. good for building a rubellion clone £25 for binaccle with trim but no switches. switches are extra, £25 for ign switch with key- same as all brit and american 60s GM, impala etc. others will be offered once tested.
as yet unidentified dash panel, pretty cool, but pitted. £25.
bakerlite smiths heater, from an early minor i believe. minor damage to top edge of air outlet as can be seen in pics, more or less hidden when fitted. tested and working. £50.
alloy 'snail' type smiths heater, fitted to various brit motors. 12v, tested and working. £30.
ford anglia 105E 8" drum- front or rear. good nick, surface rust. £25.
pair ford anglia 105E front backplates. surface rust, wheel cyls would rebuild i think, some hardware fitted. £25.
single ford anglia 105E front hub, good studs and bearings, £25.
single ford anglia van wheel 13"x4.5". deeper dish/wider offset than a normal 4" anglia rim. £25.
theres a LOT more to come, these are the vehicles we have to go back for-
2x100e engines- SOLD.
a dismembered 105e to get the axle off it- now broken up.
2x mk2 cortinas, 4dr, X-flow, one maybe restorable, one parts car. BREAKING PARTS CAR NEXT, '67 MK2 1500 DELUXE.
a corsair, 1500, 4dr, restorable, complete.
a 1960 mini rough but restorable
theres also some really curse word stuff only good for parts-
thames 400e chassis-cab wrecker truck with crane,
CA bedford
70s mini
a35
a55
FD victor
moggy minor + 2x traveller,
HA viva plus at least one in bits
a couple of maxis
another big van full of curse word
an allegro (on the road or close to)
a metro and a metro turbo
mk4 scrote x2, a 2dr and a 4dr, plus mk4 scrote van
a zodiac thats fallen in half,
a F series victor thats also fallen in half.
and we didnt get into the wheels/engine shed or the panels shed as the brambles were too overgrown........
all items can be posted with the exception of the seat I think, paypal accepted. all items located manningtree north essex.
phone suits me better than posts or PMs at the mo, 07746334088.
update, pt.2-
CA bedford
70s mini
a35
a55
FD victor
a couple of maxis
