ems1
Club RR Member Number: 5
Noisy Axleems1
@ems1
Club Retro Rides Member 5
My Manta has a ZF lsd that is noisy when accelerating or under load (when going up hills, etc). When off the throttle and going down hill it's quiet. Is it likely to be the bearings, cwp or lsd side gears that needs changing?
Thank You
Last Edit: May 1, 2013 19:48:36 GMT by ems1
1985 Manta GT/E 16v 2001 VW T4 Caravelle
Some of them are quite noisy,have your tried changing the oil,,ifs its not the right stuff it will whine like a b*tch,although I'm not sure about the slip diff,the pinion bearing wear can show a drone under load.If its there after a while of driving ,when the oil is warmed up ,id say thats the place to look.But id try refresh the lsd oil,someone may have put hypoid in there?
