1275 marina engine and gearbox complete with ancillaries. This was removed from an accident damaged car two years ago (side impact). It was running good right up to the point it came out. The engine and box come with an Owen burton modified back plate which will raise the starter motor to clear the chassis leg on the driver side of the minor engine bay. It also has a custom made propshaft to mate the marina gearbox to the minor diff. You will need a standard minor front plate if you wish to use the minor engine mounting towers or you could fabricate mounts to match up to the marina mountings on the block. Looking for £250.00 for everything.
I am in Paisley in Scotland, which may put off some of the guys based in the south but I will be going to Portsmouth on the 18th or 19th of May in a van so could deliver for a contribution towards diesel within reason along the way.
Cheers Barry
Cheers Barry
