A pair of Rover Recaro front seats from a Rover 800 Vitesse. Subframes fitted are the original Rover ones with the height adjustment machanism for the driver.
These seats can be fitted to most cars if you construct seat runners as the bolt holes are standard Recaro. I have had them fitted in a Capri, Cortina, Granada, BMW E30, Vauxhall Astra with no problems. I have seen them fitted to VW Campers, Land Rovers etc
They are from a 4-door car so do not tilt, however, if fitted with longer runners they can be moved forward sufficiently to gain access to the rear of a 2-door (as I had them fitted in my Capri Mk1, Cortina Mk3 & Astravan).
www.ebay.co.uk/itm/271192121411?ssPageName=STRK:MESELX:IT&_trksid=p3984.m1586.l2649
