Apr 11, 2013 17:41:30 GMT
Hi
About a year ago a neighbour gave me a 99 S type V6 with manual gearbox after MOT failure on rust. I've just got around to doing something with it but can't get the damned thing to go.
Always started and ran fine until being parked up and now it won't fire. The battery went flat over that time so I replaced it with another, checked all 3 fuse panels but nothing obvious amiss.
Central locking still works off the blipper. I can't hear the pump run and a squirt of 'start you sod!' down the air intake shows it's not firing either....
Suggestions?
Last Edit: Apr 11, 2013 17:52:26 GMT by peanutsc
91 Citroen BX Diesel Estate (on the road) 85 Merc 200T Estate 83 Peugeot 205 (on the road) 61 Mini Convertible (on the road) 91 Ford Transit (on the road) 77 Mk1 Transit 60 Rover P4 100 (on the road) Various Moggies/Minis. Plus several others...
v8ian
Apr 11, 2013 17:48:46 GMT
on my BMW when I have had the Battery off I sometimes have to cycle the remote. I think its about 10 times I have to lock n unlock the car with the remote, then it will start,
Apr 11, 2013 17:51:30 GMT
Thanks - will give any easy suggestion like that a go! Have also check the pump cut off and that's still down.
hairymel
avatar by volksangyl
Club RR Member Number: 207
Jaguar starting problem...hairymel
@hairymel
Club Retro Rides Member 207
Apr 11, 2013 20:05:38 GMT
sounds like could be immobiliser issues. my dads xj8 needed a couple of open/lock cycles before it deimmobilised ,the last time it had a flat battery. tldr lock and unlock it a few times with the (actual) key
Last Edit: Apr 11, 2013 20:06:49 GMT by hairymel
whats that burning smell?
oh curse word :-(
Jaguar starting problem...ChasR
@chasr
Club Retro Rides Member 170
Does it turn over? IME most Fords will not even turn over without the immobiliser disarming. I would expect Jags of this era to be the same. I would be looking to the crank sensor if it is refusing to fire up. No amount of East Start will start it with a duff one (short of the engine dieselling ). On two occasions I have had crank sensors randomly die on me (fortunately either at home, or near home).
Last Edit: Apr 12, 2013 7:06:33 GMT by ChasR
Thanks for the comments. I'll try the locking first.
Yes it spins over normally and everything else works but just doesn't fire. I am no fan of easystart due to the engine damage caused from over use but a quick squirt does tell you quite quickly whether or not there is a spark (plugs etc are well buried on this car in particular)
The crank sensor crossed my mind too so will try this next.
Will let you know how I get on!
Apr 13, 2013 18:53:49 GMT
Sadly no luck with the blipping and key action - still won't go. Thinking about the crank sensor - surely I'd still hear the pump run if this was at fault?
get a timing light gun to see if you have spark, then check the fuel pump wiring and relays.
ClassicResto.co.uk - Restoration and maintenance of classic cars - Wolverhampton.
2002 Mercedes E320CDI Estate 1998 Mercedes C240 Sport 1995 Mercedes SL500 1993 Mercedes 500 SEL 1993 Mercedes 500SL - Sold October 2022 1989 Mercedes 300 CE 1985 Mercedes 500 SEC 1985 Porsche 911 Carrera - Sold March 2022 1983 Porshe 944 1978 BMW 1602 1973 Mercedes 350SL
richp
I've had to replace coilpacks on my Dad's one, might be worth checking to see if any moisture has got in there and killed them.
Manual s types of this era only immobalise the fuel and ignition Sometimes if the battery is left flat for ages the system can lock out.Try disconnecting both battery leads from battery and touching together for a few seconds.Reconnect battery and try again
May or may not be of any use but with the P38 Range Rover, you needed to turn the key in the door lock a specific number of times in both the lock/unlock directions before it would love you again. First time it happened to be, after a battery change, contacted LR and they gave me the vehicle specific code. After that, whever the battery came out I used a piece of wire with croc clips to maintain continuity.
