Yup 4x100, I fitted MINI One 15" Steel wheels to mine with good effect: 1983 Triumph Acclaim by RSdesignUK, on Flickr Triumph Acclaim 1983 by RSdesignUK, on Flickr Triumph Acclaim 1983 by RSdesignUK, on Flickr They are great cars, but some parts can be really hard to find, and they are not cheap to lower as there are not many Mk1/Mk2 Civics or Acclaims that have the replacement lower springs, they were custom units from SPAX IIRC. With wider wheels (185/55/R15 from 145/80/R13) they were a LOT better in the wet and grip although tramlined like a b*tch!
For some strange reason - ive always wanted an Acclaim! Searches ebay...
Current retro - 1996 Alfa Romeo GTV / Daily - 2016 Nissan Qashqai Previous retros - Prelude, Integra, XR2s, XR3s, Orions, CRXs, Sylvia S12, S13, Pulsar, ZX 16v, 205 Gti, MX5, MR2 etc
danb93
I'm still having thoughts about getting one of these and dropping a D/B16 lump in it for ultimate Grandad spec sleeper. How hard could it be?? Nice drop, set of SSR Star/Mesh/Work Equip and you're done Bringing back an old thread 😂 I made it happen.
Last Edit: Nov 6, 2018 0:11:27 GMT by danb93
Holy thread revival batman. However, worth it! all of the win right here with that.
retrolegends
Winging it.....Since 1971.
Club RR Member Number: 94
More info and pics please 👍🏻
1974 Hillman Avenger 1500DL1992 Volvo 240SE1975 Datsun Cherry 100a flying custard1965 Hillman SuperMinx Rock N Roller1974 Austin Allegrat Mk1 1.3SDL1980 Austin Allegro Mk3 1.3L1982 Austin Allegro Mk3 on banded steels2003 Saab 9-3 Convertible 220bhp TurboNutter1966 Morris Minor 1000 (Doris) 2019 Abarth 595C Turismo (not retro but awesome fun) www.facebook.com/DatsunCherry100a
Could we have some better pics of wheels and stance please?
That is well cool danb93!!
danb93
More info and pics please 👍🏻 What would you like to know? Here is the spec list. Me & my friends thought it would be a funny build/sleeper so I bought a B16 powered EJ6 Civic as a donor & used a rotten beige shell for a mock up earlier in the year, did a track day to test it then recently swapped it all into a mint shell & turbocharged it for good measure! The engine & box is actually wider than the bay so it's a very tight fit. I had to cut holes for the pulleys to run in and mount the engine almost solid because there is no room for movement. I've built it as best as possible to use as a daily drive so everything has been done properly & looks tidy. B16A2 Stock Engine GT3071 Turbo BWR Ramhorn Manifold Tial 44mm External Wastegate & Screamer Pipe 3" Downpipe > 2.25" EJ6 Civic Exhaust 2.25" Shallow Intercooler Kit Electronic Boost Controller 044 Fuel Pump OBX Fuel Rail 650cc Injectors Adjustable Fuel Pressure Regulator Hondata S300 Bluetooth Standalone ECU 3 Bar GM Map Sensor Launch Control BKR8EIX Plugs NGK HT Leads Big Electric Fan On Stock Rad Hydraulic Clutch Conversion 4-Puk Paddle Clutch Lightweight Flywheel LSD Gearbox Custom Driveshafts (B Series Inner, Acclaim Outer CVs) 242mm Civic Vented Front Brakes BC Racing Coilovers AXE 8 15x8J ET30 Wheels Nylon Engine Mounts 195/50 Nankang NS2R Front Tyres 195/45 Nankang NS2 Rears Integra DC2 Import Recaro Seats Momo Dished Suede Steering Wheel EG Civic Gauge Cluster Boost Gauge It made 346hp at 0.85bar (High boost) & 255hp at 0.5bar (Wastegate pressure). Even on low boost it will spin the wheels in 3rd in the dry. I have wired the boost control map into the heated rear window switch, so a simple press of that unleashes another 100hp! The rev limit is currently set to 8300rpm with VTEC around 5500 but these engines are safe for 8500+ stock. I think we saw 8950rpm on the dyno at one point. Videos to follow soon!
Last Edit: Nov 6, 2018 0:00:42 GMT by danb93
danb93
This was the test mule in N/A form.
Last Edit: Nov 6, 2018 0:04:24 GMT by danb93
danb93
danb93
danb93
danb93
danb93
slater
Club RR Member Number: 78
Nice. Wish i could have done similar back in the day.
retrolegends
Absolutely brilliant and a real credit to the amount of work you've put in, sounds brutal. edk83 fancy a drag race??? 👍🏻
