Mar 14, 2013 17:38:12 GMT
Hi folks! My dolomite has come with a 70s aftermarket cruise control unit. Pictures: What i need to pick your brains on, is how you think it operates? It runs in series with the throttle cable, i initially thought it had a pull cable to lock it on but from looking closer ive discovered its got a loose connector with nothing attached to it, so it appears to be electronic. There doesnt appear to be a switch for it, so i think someones removed it so it cant be used in the past, anyone any ideas how youd get this thing working again? Itd be pretty cool to get it working, thats for sure. Cheers for your time.
Mar 14, 2013 17:47:22 GMT
Just found this with a quick google:
I'm not sure this one was for trucks, cos theres no second battery, but it appears I'm missing a control unit! Ideas on that front? or am i screwed..
Mar 14, 2013 18:32:36 GMT
Wow, I've always wanted to see a car with one of these set-ups fitted!
They were advertised heavily in 70's car mag's as the thing to have in order to aid driver comfort and fuel consumption etc...
It's a shame the control unit isn't in place as that's what you need to get things working! I'm sure somebody on here will be able to help surely?!
***GARAGE CURRENTLY EMPTY***
squonk
Mar 14, 2013 18:33:08 GMT
Mar 14, 2013 18:35:31 GMT
Mar 14, 2013 19:57:44 GMT
And completely misadvertised. Should get it for a steal
Mar 14, 2013 21:13:04 GMT
You sir, are a wizard! I think i actually saw that but thought it was a train thing for real ahahah (nobody bid i need this!)
Mar 14, 2013 21:14:02 GMT
Also cant beleive how cheap the NOS one went!
Seller just kindly ended it early for me!
Cheers for that one grifterkid, thats saved a lot of aggro, next step is to work out how to wire it in.
Lol!! Ive had a control box for one of thease kicking around for years!!! But only just spoted this thred.
matty2300
Red ones go faster!
Mar 15, 2013 13:14:24 GMT
Ive got a sort-of-dangerous 1970's cruise control on my firenza... I fitted a weber dgas, with the choke flaps removed but retained the choke cable - end result is I can get about half throttle just by pulling out the choke lever without any of the "choke" action - will happily cruise with no pedal input - just pray you don't have to brake!
2002 Saab 93 - Daily 1972 Vauxhall Firenza Sport SL - in storage 1978 Vauxhall Magnum - PROJECT 1993 Vauxhall Cavalier 2.0 GLS - DEAD 1994 Vauxhall Astra 1.4 LS - DEAD 1999 Saab 93 2.0 SE - DEAD 1999 Mercedes W202/C200 - DEAD
Mar 15, 2013 13:21:11 GMT
Mine just locks the throttle electromagnetically i think, and stops when you brake. Lol!! Ive had a control box for one of thease kicking around for years!!! But only just spoted this thred. Want rid per chance?
Mar 15, 2013 13:59:05 GMT
Good to see you nabbed that control unit...!!! Now I cannot wait to see it all set up...
Mar 15, 2013 16:29:32 GMT
end result is I can get about half throttle just by pulling out the choke lever I've got an old V-twin Yamaha bike that does that. I use it when I'm commuting, crunch it up and sown the gears to control* the speed. *it's not really under control, it idles so roughly the speed varies massively.
rld14
Just read the Cal Custom link, yup I've seen these before. Biggest weakness in the system is a vacuum leak that or magnets falling off the driveshaft.
As a side not my '60 Lincoln has FACTORY cruise control. It's a neat setup, totally mechanical with an electric motor for throttle control. It is a "Speedostat" made by the Perfect Circle corp, basically the first generation cruise control units ever sold.
88 BMW E28 M5
62 Vauxhall Velox
60 Vauxhall Velox
60 Lincoln Premiere Coupe
60 Lincoln Continental Mark V Convertible
54 Ford Customline Fordor
32 Ford Roadster
