16" bbs rx2s in fair condition
6.5j wide
et42
full set of 4. the lips would benifit from being re-cut or re-polished, the centres are fairly tidy, but not perfect. They are in pretty typical 10 year old bbs rx2 condition. I.e. they need a bit of tlc. polish the lips up and they would look pretty decent. All of the lacquer has been stripped from the lips.
Tyres are past their best. two have legal tread, but that doesn't mean they are worth using.
£145 collected from chipping norton, oxfordshire
will only hold them if a 10% deposit is offered, if you back out of the deal without good reason, you loose the deposit. If you decide they aren't as described, you get the deposit back, simples. otherwise it is first come first served.
6.5j wide
et42
