Owned 5 years. Midnight blue, factory grey leather electric heated Recaros (very nice this time of year!)
125k FSH up until last summer where I just could'nt justify paying someone £140 to change the oil anymore so did it myself and kept receipts.
It had a trip to Stealth 2 years back for a health check, chains are quiet as is the engine in general it's been owned by older people who moved on to a new Scirocco and then me, an enthusiast.
While at Stealth it had every bush, bearing, mounts etc underneath changed (some upgraded to R32 equivalents) out with OEM parts and the KW's fitted. (This cost about £1400 minus the Coilovers!)
KW Variant 1 coilovers (cost around £600)
288mm brake upgrade with D&G Braided hose kit to the front.
I have changed the heater matrix, swapped out the old adjustable steering column as it had play in for a rare fixed unit from an 8v. Speedlines all in great condition good recent new Falkens on front and OEM Bridgestones on rear.
I have also changed the foliage seal with a new OEM one after a slight water ingress this has stopped the leak altogether.
Has 12 months mot and 6 months tax.
Just had the front bumper re painted as was stone chipped and had some marks on.
Has an un named stainless exhaust which sounds great, not too loud and a de cat pipe, tailpipe is oval similar to OEM.
I have the old system and cat, the old original suspension in good condition aswell.
3 sets of keys.
2 new ABS sensors for mot, none of this taking the bulb out nonsense.
Scorpion immobilliser.
A really sorted good usable car that still gets over 30mpg and drives really tight and really does fly.
Classis insurance is pretty low for the performance you get on these.
Spoiler goes up and down correctly.
Bad points are, slight bubbling above rear number plate light, sunroof does not always work, can be manually wound with an allen key and does not leak most importantly.
Passenger Recaro has stopped adjusting backwards, have taken the switch off to stop people moving it further forward. Heating element still works though. Minor wear to driver bolster as to be expected.
Looking for about £2750 come spring but open to close offers.
One drive in it and you would know its a good one. I will no doubt regret selling, but it doesnt get used.
Car is in Chelmsford, Essex. Viewing recommended, you won't be disappointed.
Pics below; contact me on here or call Gavin on 07789861392
3 sets of keys.
