Hi guys, my mate is breaking his volvo befor it gets draged to the scrappy tuesday and he said i can have the turbo if i remove the parts as he works quite alot and I'm fresh out of a job, I'm looking to put it on a swift gti 1300 engine which has had a fresh rebuild but useing standard internals, i no there good for 16psi without any dramas on the engine but I'm usure if the turbo is too much?. All the swift guys normally use the td04 from the scooby and i no of one person running 26psi with nos and no trouble there with that. So will the volvo turbo be alright?
Thanks in advance for your help guys
