rld14
I have always wanted one of these, and this one, well.. it showed up on eBay out of Southern Illinois in August of 2011. Combination of color, an incredibly rare option and decent cosmetics and a low price meant that I had to have it. The 58-60 Lincolns were the first Unibody cars (Along with the Thunderbirds) that Ford made in the US. These were equipped with a 430 cubic inch V8 (7L) that in the 60 models, due to a 2bbl carb, produced 315hp and 465 lb-ft of torque. This car used to belong to a former US Congressman and is equipped with standard Premiere equipment (Automatic, Power windows and seats, signal-seeking AM radio) plus factory Air Conditioning, "Directed Power" differential (Limited Slip), and the incredibly rare speed control. That's right, factory cruise control. In 1960! It's lacking power vent windows, 6-way power seat (It's a 4 way), power locks, power trunk release and FM radio. Solid body, mostly decent chrome, partially repainted and only 41k miles! It weighs over 5,000 lbs and is huge, these were the longest pre-73 cars built by Detroit aside from Limos. So... here's what she looked like when she arrived in New Jersey... And the dash, you can see the Speed Control dial at the far lower left of the dash..
Last Edit: Feb 27, 2013 10:09:01 GMT by rmad
88 BMW E28 M5
62 Vauxhall Velox
60 Vauxhall Velox
60 Lincoln Premiere Coupe
60 Lincoln Continental Mark V Convertible
54 Ford Customline Fordor
32 Ford Roadster
rld14
When she arrived I knew that the car had been off the road for at least 10 years... and it was sitting on a set of 225-75R14 narrow whitewall radials. No. First, IMO, radials look stupid on these cars and those are way too small, original size was 9.50-14 and I ordered a set of BFGoodrich Silvertowns from Coker. Basically to get it somewhat roadworthy I went and redid the front brakes, brake hoses, (Master cyl and "Treadle Vac" booster were thankfully good), The fuel tank, hoses, radiator, thermostat, belts, (It uses double V-Belts), fuel pump and filter were changed, gas tank cleaned out, radiator recored (4 times but that's another story), power steering pressure line, fuel lines, one muffler, and I know I'm forgetting a bunch of stuff. Here's what I ended up with..
88 BMW E28 M5
62 Vauxhall Velox
60 Vauxhall Velox
32 Ford Roadster
rld14
And it drove rather well... And it made it to a few local shows last year, here it is with a 1960 Cadillac Eldorado convertible.. Then disaster struck, the engine developed a loud ticking noise. Turns out the rocker shaft on the passenger side was clogged up, the driver's side was fine tho. So I replaced the rocker shaft and rocker arms.. now it's nice and quiet and oiling very well.
88 BMW E28 M5
62 Vauxhall Velox
60 Vauxhall Velox
32 Ford Roadster
rld14
To give you an idea of the size of the thing, it's parked in front of my Lexus GS350 (GS300 in the UK) in this shot.. Also, my friend picked up a nice 59 Coupe.. we finally got them together for a pic.. I've also driven it into Manhattan a few times... it turns heads like nothing else. The black car is its' great great great great grandchild.. Took this shot outside the local Lincoln dealer.. Current needs: It could really use a paint job, or at least the roof. The heater cores both leak and are bypassed. The Air Conditioning system needs a total overhaul. Yes, it uses Evaporators and heater cores on EACH side of the car. I have a new exhaust, havent had time to put it on Transmission is rebuilt, engine runs OK but has blowby, seems to be caused by a leaky intake manifold... Cruise control and speedo are inop. It's a work in process..
88 BMW E28 M5
62 Vauxhall Velox
60 Vauxhall Velox
32 Ford Roadster
Rob
You know, for kids!
Gorgeous! The roofline is so low for a '60 car too.
Any modernisation plans for it or is she staying stock?
79cord
Garish & amazing. So they didn't chrome the roof then.
Feb 27, 2013 10:36:15 GMT
I like a boot (trunk) big enough to get TWO bodies in!
Currently: 1974 Beetle - Golf -
Previously: e38 735i, e34 525iSE, 1972 Beetle, 1991 Scirocco Scala, Morris Minor, 1983 Polo Breadvan, 1991 Mazda MX6
rld14
Feb 27, 2013 16:14:29 GMT
She's going to stay largely stock, I'm debating about the stereo right now. I had been running something called a redirad in it that plays aux inputs over the original AM radio, but then the radio decided to let all its smoke out.
So I'm thinking... Do I fix the radio or do I have the internals updated to play FM, hide an amp and put real speakers in the thing?
I'm also toying with the idea of a front disc brake conversion but I'm not sure that a modern booster will clear the cruise control unit under the hood, I mean bonnet. It's going to need new front drums and used ones that are serviceable are $250 each! They are unique to 1960 Lincolns unfortunately and none have been made in probably 45 years.
It also needs new weatherstripping, that's going to be quite the job... What's reproduced is expensive and ill-fitting, I haven't found anything yet for most of it that I can make work, especially the window seals.
What else... The engine is where, long term, I'm going to have fun. 58s were available with a dealer installed tri-power setup that gave them 400hp and over 500lb-ft of torque. Even a stock '58 which had 10.5:1 compression and a 4bbl carb (59+ are 10:1) would hit 60 in under 9 seconds. I figure a tri power engine with a cam and the right ignition setup would haul some serious butt.
Oh and I think I've found Bilsteins for the thing, but surprisingly it handles VERY well for a car of its size and era, much better than a comparable Cadillac or Imperial. It can easily keep up with modern traffic on curvy roads, as long as you don't have to stop.
I've also been toying with the idea of a 4bbl intake (I have one) and a hidden EFI setup, that'd also help economy as fuel isn't cheap over here anymore. It's still cheaper than in the UK, but $3.99 a gallon and 8-9mpg in town and maybe 12mpg on the highway is painful to the wallet.
Last Edit: Feb 27, 2013 16:15:09 GMT by rld14
88 BMW E28 M5
62 Vauxhall Velox
60 Vauxhall Velox
32 Ford Roadster
Feb 27, 2013 18:12:18 GMT
Phenominal, beautiful, absurd. I didn't even know these existed until now. I can't get over the fact it's a two door, what an astonishing thing it is!
Feb 27, 2013 18:14:09 GMT
Gorgeously ugly. Love these. I missed out on (or chickened out on) one of these for £1500 a few years ago. Seriously rusty mess of a car. Shame.
Feb 27, 2013 18:53:06 GMT
That picture looking over the steering wheel in Manhattan, that's just about as cool as it gets.
Awesome ride!
Rob
'55 Austin A30
'71 MGB GT
'72 Datsun 240 shed
'72 Mercedes 240D
'79 Firebird
'86 Austin Maestro Van
'91 Mercedes 250D
'91 BMW e34 535i Sport
'92 Mazda MX-5
gt350
Feb 27, 2013 19:50:45 GMT
thats a big car,its in super condition
rld14
It's so ugly it's beautiful! Alastair, that was probably a good move. Parts are rare and hugely expensive for them, I would NEVER restore a basket case. Need pistons? That's $1200.
88 BMW E28 M5
62 Vauxhall Velox
60 Vauxhall Velox
32 Ford Roadster
rld14
I like the wrap-around rear window, but the Continentals have a reverse-slanted rear window, like a 105E Anglia.. except that the center part of the rear window is electric, it slides up and down.
88 BMW E28 M5
62 Vauxhall Velox
60 Vauxhall Velox
32 Ford Roadster
love it i would not change how it looks in any way
rld14
Took it for a spin this morning... froze my butt off.
I think it's really time to tackle the heater cores.. no, wait, it isn't. Spring is here (Even if it's still cold).
It has TWO heater cores hidden behind TWO AC Evaporators. Both heater cores (Matrixes) are leaking, so I have no heat.
88 BMW E28 M5
62 Vauxhall Velox
60 Vauxhall Velox
32 Ford Roadster
Joe T
Love it!
Best of luck with all the work you're doing on it.
Stu
Mar 24, 2013 15:56:32 GMT
Wow!
