tee
Feb 14, 2013 11:55:47 GMT
Got a merc that was cat c and the guys run out of money so it hasn't had it's vic test done. Wanted to know if it's a lot of hassle or as simple as an Mot. All work has been completed to bring the car up to scratch, how do you go about booking one and what kind of costs are involved. Also car still has MOT until mid this year, is that now void or still valid?
T
Feb 14, 2013 12:02:59 GMT
basically the vic test is just to check the identity, nothing else.
1993 Fiat Panda Selecta 2003 Vauxhall Combo 1.7DI van 2006 Mercedes Kompressor Evolution-S AMG SportCoupé
"You think you hate it now, wait til you drive it"
crazymonkey
ummm....what was I doing again???
Feb 14, 2013 16:44:46 GMT
vehicle identity check is literally that. checking the identity to make sure there's nothing suspicious going on. they don't check the quality of repair work as far as I know, purely the VIN numbers, chassis numbers etc to make sure it is what it says it is.
and as far as I know you'll have to have it MOTd again. pretty sure the MOT is void when its written off.
whoever said dogs were man's best friend....obviously never heard of cable ties
hamps
www.medwayrscentre.co.uk
Feb 14, 2013 17:36:25 GMT
Re mot then book a vic check price includes new v5 document
All they check is the ID that's it, no repairs etc
Feb 14, 2013 19:54:32 GMT
i put a car in for vic check(its not a test) with new mot,but no repairs done(slight dent on arche) no problems what so ever. they even commented that it should'nt have been a cat c.
Feb 14, 2013 19:59:32 GMT
Mot is void so re MOT then take to vic test. The VIC test is nothing to worry about unless your hiding something. Test is about £40 last time i did one, takes about 20 mins to do, simples.
1977 datsun 810 180b estate
richrolls
Club RR Member Number: 38
Feb 14, 2013 20:04:04 GMT
I have taken cat c cars for vic tests. You have to MOT them 1st if you're going to drive it there. Quote "a car can only travel on the road (read under its own power on the road) without an MOT to and from a pre arranged MOT test". It'll need insurance on as well if you're driving it there. I sometimes use the short term stuff. It works out cheaper that a transporter at times It takes minutes in some cases. I my opinion: I believe they are only looking for rung/cloned/stolen cars. I took a Plum coloured 2006 1.4 16v automatic 5 door Corsa and was there 5 mins, there can't be many other cars matching that.... Take a silver mid spec BMW, Merc, Ford and you'll be there a bit longer. You arrange it online to start with via the GOV/VOSA site and your chosen centre will then contact you. It is very easy. don't be put off
Last Edit: Feb 14, 2013 20:08:22 GMT by richrolls
