Feb 13, 2013 17:37:42 GMT
Wonder if anyone can shed some light on this. I have a mk2 golf which has let water in since I got it. The windscreen has been out and the frame has been rewelded where there was bits missing, all seam sealed and painted back up. The A pillars were solidified too... However it still leaks water in. I've used food dye and poured different colours in different bits. The sunroof, rain tray, doors don't leak. The windscreen does. Can I pump grease/silicon/special stuff into the gap between car and seal, it's getting right on my nerves now! Thanks for reading.
Last Edit: Feb 14, 2013 2:48:07 GMT by barnesy
Feb 13, 2013 18:52:08 GMT
Last Edit: Feb 13, 2013 18:53:12 GMT by cobblers
Feb 13, 2013 18:54:33 GMT
ooh! Is that to be put in when fitting or can I pump it in with the screen in place?
Feb 13, 2013 20:06:20 GMT
Ideally you need to fill the groove of the seal up with it before putting the wire in the seal to pull the screen in. I suppose you could try and pump some in after the fact, but you stand a good chance of getting in a mess and still having a leaky screen - it depends how far you can pull the screen seal back I guess.
Feb 13, 2013 22:45:48 GMT
Gutter sealant! Works a treat, amazons always leak, not mine! You use it in a mastic gun, inject it under the seal to fill the void and wipe away the excess with white spirit.
Feb 13, 2013 23:02:47 GMT
halfords seek and seal does the job
Feb 13, 2013 23:33:22 GMT
Captain Tollys Creeping Crack Cure ordered, failing that I'll be whipping the screen out and resealing.
Thanks for the advice men.
Sounds to me like the rubber has seen better days and gone baggy, new rubber and clean the windscreen apeture well, string it in job done, the rubber on a mk2 golf has channels on the back which makes the rain water run along to drain away, they are a dry seal rubber from the factory so should not be sealed but changed if leaking.
MK2 Cortina Estate
