This is a great engine built by Mick Wilkin a respected engine builder,
intended to go in a mk1 escort van , no longer own van so needs to go.
1690 cross flow roller rockers, Vulcan ful lrace head,
Bought this from Mick Wilkin a while ago, not been used but dry stored correctly.
is now surplus to my needs. Has all the right bits spec below
Looking for £1000 OVNO call oh7960202501
Block - +60 to 1690cc - Balanced and lightened rods - crank balanced and not lightened - machine bore to pistons 2 1/2 thou clearance - if using slipper pistons 2 thou clearance
lightened fly wheel to 7.5 klios clutch to suit - end float on crank 5-6 thou - vulcan full race head A6 camshaft - roller rockers --- deck of block machined 120 thou or 3 mill then use 3 mill spacers under rocker shaft pillars - wet or dry sump 4 185 bhp use 48 mm twin webbers with long inlet
Hope this helps you
cheers Paul
Hope this helps you
cheers Paul
