Got a lovely set of Alfa Romeo Alfetta wheels for the Lardarse - they go on the back, but not the front! Apparently this is right as for some reason Lada centrebore is slightly bigger at the front! It's only by a smidge - I'd presume I should get a flapper wheel of slightly larger diameter than I want the finished hole to be and be very gentle with quick bursts of the drill - anyone care to correct me or agree with me? If hate to knacker these lovely rare 34 year old wheels! Wheels are somewhere around 58.something and so is the centrebore so it's literally as whisker that needs to come off. Dave
Surely you have a friendly local engineering company that will turn them up on the lathe? The flap wheel could work, but I wouldn't like to try it! A mate of mine works for Allied Hydro Power and they have a place in Birkenhead if that's any help?
Yeah, a big flap wheel would be fine if you are talking small amounts like this, just keep it stirring around so you don't focus too much on a particular corner and you'll get things more than accurate enough.
Last Edit: Feb 9, 2013 18:16:11 GMT by cobblers
Paul
+1 for flapwheel.
I had to shave 1mm off the circumference of some Rover BBS wheels to fit on my Golf because of the scene tax on VW bore...I had the benefit of a hubcentric spacer to hand so just spent a couple of minutes on each one, job done.
whilst a flap wheel will work would it not be better to get the hubs on a lathe to match the rears?
Cheers fellas, thought as much - and I'm on a ridiculous budget at the moment so getting them machined for a tenth of a millimetre isn't really an option! I need to get some bolts too as my Lada ones are too short - they are M12x1.25 but stubby little chaps, I'm thinking of getting some second hand ones from something with the same bolt pattern but longer, not sure how long they need to be as if they are too long they'll hit the gubbins in the brake drums. I'll probably try one and cut it down to suit. Anyone know another car that shares the same alloy bolts? *off to google*
Feb 10, 2013 10:04:15 GMT
Peugeots (106 206 306 etc) are the same thread, normal bolts for steelies are 60degree taper.
Dez
Club RR Member Number: 34
Feb 10, 2013 20:46:38 GMT
ive got a pair of front hubs machined to 57.1mm, they're also double drilled to 4x100 as well, and have 2.5" long studs fitted.......
Dez
Feb 10, 2013 20:54:15 GMT
oh yeah, and ive got a set of long wheel bolts for the rear too
nitro
Feb 10, 2013 22:30:21 GMT
There is a company that dose it but I'm unsure on the price, www.tttoolsltd.co.uk i got quoted 150 for re-drilling a set of alloys
