Ryannn
Hallow, I have a Peugeot with a battery teminal like this... It keeps working its way loose causing the engine fault light to come on and the car not functioning the nect time you try and start! Before I have a squeeze with the plyers... does anyone know if you can tighten these or whether you can replace them? Thanks
Afaik they're crimped on the lead and not available separately.
chop it off, and fit a "normal" style battery clamp
chop it off, and fit a "normal" style battery clamp This is what I did no bother since.
Ryannn
Think I will yeah, got one in the tool box!
I did have a bit of bother with these on the other halfs 206 GTI. The garage fitted a battery that was not quite as tall as the original, so the plastic box round the battery would push on the connector and eventually cause it to come off. Correct battery fitted - no problem.
Ryannn
I did have a bit of bother with these on the other halfs 206 GTI. The garage fitted a battery that was not quite as tall as the original, so the plastic box round the battery would push on the connector and eventually cause it to come off. Correct battery fitted - no problem. That's exactly what this is doing! I'm either going to space the battery up or trim the box a little as it's going to be a bit late to change the connector when the car comes back.
