Hi all
Looking for a bit of electrical advice really...
Have a pic of her in her new home where she will be spending the next month or so....
img.photobucket.com/albums/v298/Delorean/72F2A951-CDD2-4F54-8F75-0FB57F7C002D-566-0000012E5F448F20_zpsc288e970.jpg
We stuck her on the jig so she can be easily wheeled about and access is a bit better
First job on my 911 and I'm stumped already!
Basically today I started to remove a load of old aftermarket/non factory wiring which included badly a wired stereo harness and an old meta alarm/immob that was out of use and had been for some time.
I wanted the wiring to be as clean as poss so I was carefully tracing everything back and removing the stuff that is definitely redundant.
However, the non stock relay which drives the fuel pump has somehow ended up being disconnected (I can't think how ) and the car won't start... It wasn't wired great - There seemed to be two grounds to the relay among other things.
The car has the old style inline fuses with screw terms at either end and I can't work out where the cable goes from the fuse and am basically very confused.
What I want to know is what feeds will go to the relay, and what is the easiest way of testing the wires I have available so I can rewire the relay?
I've looked at the Haynes manual wiring diagram but it doesn't really help me!
Any advice appreciated
... Or if you are in Leicester and fancy having a look with me I can happily accomodate with tea and biscuits
Cheers!
Cheers!
