rob0r
East of England
Club RR Member Number: 104
1972 BMW E3 3.0sirob0r
@rob0r
Club Retro Rides Member 104
E30 320i 3.5 - E23 730 - E3 3.0si - E21 316 M42 - E32 750i ETC
rob0r
East of England
@rob0r
So I picked it up on Friday and got stuck in for a few hours in the afternoon Supplied with no interior, pre-stripped The car for what and how old it is, is in fantastic condition IMO. So far the welding list consists of a patch at the end of both outer sills, patching by the floorpan "jacking" points, a few tiny stitches around the rear wheel wells and the spare wheel well. Some pics of the rust Drivers side Passenger side The engine bay is in bits and I thought the 3.0 engine was missing it's rare injection system.... But on further inspection, someone has been here before me!! It's the remnants of an E12 3.5 engine! There were tell-tale signs, the block is painted red, gearbox bellhousing bolts were mainly loose etc. The engine is in a right state, loads of debris in side the ports of the head, and likely in the combustion chambers too. So it's still coming out as the E28 M535i engine I've got is a known good unit. The engine is nearly out, I'm currently stuck on a few bolts I need an extra pair of hands for. It should be out tonight with any luck
GavinJ
MGB 3.9 v8 Sebring
Club RR Member Number: 209
1972 BMW E3 3.0siGavinJ
@gavinj
Club Retro Rides Member 209
Nice project look forward to your progress on this.
Mark
There was a guy on here somewhere with a pair of glassfibre front wings. Look forward to seeing where you go with this.
BMW 320d (fridge on wheels)
Rob,
What a stunner!
The combination of you + E3 with no interior and half an engine tells me that good good things are going to happen in this thread.
I have no problem admitting that I'm rather jealous.
Rob
'55 Austin A30
'71 MGB GT
'72 Datsun 240 shed
'72 Mercedes 240D
'79 Firebird
'86 Austin Maestro Van
'91 Mercedes 250D
'91 BMW e34 535i Sport
'92 Mazda MX-5
^^ +1 You are at the beginning of a very long and expensive road, but I too am indeed very jealous. can't wait to see this progress.
1974 Skoda S100 tarmac car 1998 BMW 750 daily 1994 Mitsubishi Evo2
rob0r
East of England
@rob0r
More progress tonight. Style 5s tested, not sure if I'd want to go much wider to be honest plus they look alright The engine came out nice and easy I'm still weighing up options with loosing the twin remote servo system My seats will go in with very little effort
rysz
Looking good Rob!
Are you going to get this caged up? Looks like it will be shaping up to be an amazing circuit / doriftu motor.
Rysz.
Steve
Making progress in small, easy to handle chunks of awesome
Nice find dude! Gonna be a sweet ride and I suspect not that sluggish with an M motor in it and zero interior I shall be watching with interest......
rob0r
East of England
@rob0r
Are you going to get this caged up? Looks like it will be shaping up to be an amazing circuit / doriftu motor. Yes, it will be caged and that is exactly my intention Steve, unfortunately the M535i engine is just a boggo 3.5. The M535i had uprated suspension etc but the engine was ordinary 3.5, except the earlier ones like mine are 10:1 compression compared to the later 9:1 E34/E32 motors, 10bhp difference apparently. Mine will be getting the later E34 motronic injection system though so I will have the best of both worlds.
***GARAGE CURRENTLY EMPTY***
Mark
Any progress with this Rob?
Mar 24, 2013 11:06:38 GMT
Just seen this.
I do like these.
rob0r
East of England
@rob0r
Mar 24, 2013 12:49:56 GMT
Hi Mark, long time no hear Not much physical progress due to work commitments and focusing on other cars.... Like drifting my 320i! This project is more of an "as and when". That said I tried a V8 I borrowed off my local BMW specialists Angus Buchanan. I said "tried" as I'm not convinced it's going to work. Currently the alternator, engine mounts (integral oil lines built in), subframe mounts are blocking the motor from sitting anywhere near where it should be. If I manage to remedy those clearances then I would have to start the ballache of getting the RHD exhaust manifold to clear the steering box. The E3 steering box sticks out at 45 degrees, if you have a look at the E34 V8 box it runs parallel to the chassis rail. The most likely engine is going to be an E28 M535i that I already have, E21 5 speed gearbox (5 speed upgrade... with a speedo drive ), E30 M3 flywheel, E30 M20 paddle clutch. I've been mainly thinking about the brakes as I have ripped out the dual remote servos and they won't be going back. It will most likely be either an E30 pedalbox based solution or using a complete E28 hydro assisted servo system driven off the PAS pump. Other plans E12 steering box (straight fit, drops from 4.4 turns to 3.4) E28 rear axle (direct fit except rear diff/shell mount) Gaz coilovers of some description I'm looking out for a derelict E28 M30 car to rob the rear axle and braking system
Bolf
Mar 24, 2013 13:47:08 GMT
NICE , love it so far.
Mar 24, 2013 15:06:34 GMT
cool project!! love this body style
Ian
Mar 24, 2013 20:39:14 GMT
Nice cant wait to see this one done, don't want to swap a pair of those style 5's for a pair of narrower rc040's??
Cod do with one of those v8 sticking in my e36. Love the look of this, and will be nice when its done, a clues to the finished look? Colours etc?
rob0r
East of England
@rob0r
Mar 24, 2013 21:39:37 GMT
Sorry, I'm quite fond of the style 5s and they look pretty good on the E3! I would swap them for some dishy 16" which I think this car would end up with.
It will remain red and probably quite rough looking. Painting and shiny isn't my bad. So... red, rough, low on dishy 16" or 17" wheels.
Mar 24, 2013 21:56:56 GMT
what dishy 16s you looking for? only i have a set of 16x8 et16 alluline basket weave alloys with a big dish you might fancy?
This look very exciting indeed...!!!
