bead breaker?hellman
@GUEST
has anyone made there own bead breaker? i know it could be easier to take it to tyre shop but thats not allways convenient. i want a nice simple idea!!!! cheers chris.
Fit a bracket to your garage wall or something else solid about a foot off the ground. Have a long metal bar on this bracket using a hinge or a bolt so you can remove it. This bar acts as a lever. Lie the wheel down flat under the bar and press the end downwards to break the bead. Works better if you fit a shaped bit of metal to the bar to press down on the bead. Its hard to explain in text but painfully simple on practice.
google throws up this.....same principal but bolted to the wall rather than free-standing.
like this actually...
@GUEST
cheers, many thanks.
i did find a pic of using a bit of wood and running a vehicle up it until bead releases, not to keen on that though!!!
