Dez
Club RR Member Number: 34
175/60R16 nankang NS2. I want em nicely steeeeeeeeretched over my steels, I'm making the wheels myself (NOT banding..) so offset wont be a problem. do those whove done much tyre stretching think 9J will be too wide to stretch em? that 1" of stretch in each sidewall on a tyre with a theoretical sidewall of 4" or would I be better off copping out and going 8J or 8.5J? or could I even go to 10"? ive not stretched tyres like this before....
Last Edit: Jan 31, 2007 1:22:15 GMT by Dez
lebowski
Hillman Avenger, Clan Clover
175's on 9J sounds like far too much to me. Would've thought it's too much for 8J to be honest.
Jan 31, 2007 10:15:55 GMT
Few more specifics would help a little like car and offset etc to determine what may be poss, but how about just wider rubber once its done. 195 on 8 should work (its normal on 7's) but will be quite descreet so it may work on 9's. await the advice of experts...
Jan 31, 2007 10:17:26 GMT
It should work,.. I'd be tempted to go for 8.5j with 175/65 ,.. the taller side wall gives you a more visible stretch, but means there isn't such pressure on the sidewalls...
If you go really radical stretch consider putting rally inner tubes in for that added safety.
Dez
Jan 31, 2007 10:56:08 GMT
car is a very low '76 merc w115. offset will be done to suit, to get the car almost sitting tyre on arch but not quite, and so i can still steer. arches will be rolled/dollied as well. but i don't see how the offset has any consequence on what can or cant be stretched.
i don't think 195s on an 8J will be enough, the rim bed will be 5mm wider than the tyre, hardly much of a stretch... and 175/65 don't exist as a tyre size.
I'm planning to tube em anyway.
Rob
You know, for kids!
Jan 31, 2007 11:09:14 GMT
hey dez... you doing the tyres yourself or do you know someone reliable in donny ? (dougal at longstone?) need a friendly tyre man ps: how did them wheels centres work out for ya ? Rob
Jan 31, 2007 11:46:13 GMT
No the offset does not really matter if you have done your 'math' which am sure you have. just a wider tyre (like my 195 suggestion) with your current working outs may clash with the arch thats all. Plus people on here may have some exact examples for you too. didnt want to mess ya plans. seen some extreme stretch on here so 175 on 8 maybe ok sounds like you have it all planned. very impressed with this custom wheel business
Dez
Jan 31, 2007 11:51:50 GMT
ile take example pics of any size on any rim as theyll all help me firure out my final width.
i tried serching but i could only find this thread and one other with a passing reference to tyre stretching.
the wheels I'm making are very simple. it can be done with an angle grinder, a bit cleverness with a jig, and a good welder+operator.
Dez
Jan 31, 2007 11:52:47 GMT
hey dez... you doing the tyres yourself or do you know someone reliable in donny ? (dougal at longstone?) need a friendly tyre man ps: how did them wheels centres work out for ya ? Rob i don't like in donny anymore, but i know a guy wholl do my tyres there if needs be, nd its not dougal. ive not actually used the centres on anything yet.
Jan 31, 2007 12:01:35 GMT
If you are tubing them,.. 175 on the 9j is the way forwards... extreme strech machine..
Jan 31, 2007 12:02:27 GMT
195`s on a 8" wide rim is the "norm" over here at least, that or 175\50`s, on 13" wheels that is. I run 195\55`s on my 8x13" ATS`s on my manta, wich gives a nice stretch, but i think it would look far sweeter on a 9" wide wheel. Going for 195\55`s on 9x13" Revo`s on my Rekord Coup i think.
Dez
Jan 31, 2007 12:07:24 GMT
got any pics of your setup?
Jan 31, 2007 14:55:57 GMT
Go over to forums.vwvortex.com/zerosearch and do a search for 'tire stretch' whilst checking the 'archived content' box. They like a low profile stretch over there, but it's interesting reading anyway!
Jan 31, 2007 15:15:36 GMT
Dez
Jan 31, 2007 19:51:04 GMT
Go over to forums.vwvortex.com/zerosearch and do a search for 'tire stretch' whilst checking the 'archived content' box. They like a low profile stretch over there, but it's interesting reading anyway! theres actually a lot of good info there, in between the fights! it looks like 195/45 on a 8.5j rim may actually be my best option, as i want something just a touch more than the 195 on an 8
zep
Jan 31, 2007 20:03:29 GMT
Ok boys, I haven't read most of this, but here is a picture of a dude's Chevette in our club. These are 175/50R13s on an 8" wide rim. Looks great in my opinion!
racer86
'76 Toyota KP30 / '73 BMW 2002 / '93 Mini
Jan 31, 2007 21:45:16 GMT
I was looking to run 165/65 on an 8". Not tried it yet but i think its going to be an innertube job.
Philj
Jan 31, 2007 23:25:33 GMT
I don't get why you'd want to run such a high profile? 175 60 on a 8 or 9J will look incorrect.
Since your making the wheels...
I suggest 8.5s front and 9s back, both with 195 40 or 195 45 tyres. Would look lovely. A 195 on a 9J is a bit much as is, let alone a 175.
The Japanese run with a higher profile,.. it gives a much more prounounced stretch,.. its why the tyres looks so much more stretched than they really are...
The low-profile stretch look always looks scarier than the high profile one, but doesn't always look better IMO. If you pick up an old copy of Hot Car (late 60s) or similar you'll see loads of companies selling wide (banded, mostly - up to 10"!) wheels, but no source for wide tyres, in fact radials were state-of-the-art then so most people would be buying crossplies to fit those wide wheels!. The stretch look is proper retro, the lowriders have a similar story to tell. A set of 13x7s with 5.20 crossplies is still the set up to have on a proper lowrider: They're not very wide before the stretch: These ones are tiny!: The modern equivalent would be the 13x7 with 155/80:
Last Edit: Feb 1, 2007 10:28:24 GMT by rmad
