1983 VOLKSWAGEN PASSAT. £1550ono
A VERY RARE CAR THESE DAYS, SINCE I'VE HAD IT I'VE NOT SEEN ANOTHER ONE.
1983 B2 VW PASSAT GL5,
JUST OVER 121K ON THE CLOCK, WITH THE MOST IMPRESSIVE HISTORY I HAVE EVER COME ACROSS, WITH EVERY RECIEPT inc THE DEALERS RECEIPT OF SALE AND EVERY MOT CETIFICATE.
X2 KEYS
THE PASSAT DRIVE'S PERFECTLY WITH NO ISSUES & IS A QUICK LITTLE THING .
100 MILES AGO IT WAS FITTED WITH A BRAND NEW WATER PUMP AND CAM BELT.
MOT UNTIL END OF NOVEMBER , had the rear shock replaced, though it didn't need this to pass.
BRAND NEW BATTERY FITTED 3 WEEKS AGO
ALL FOUR LOW PROFILE TYRE'S ARE THE SAME AND HAVE ONLY DONE AROUND 200 MILES SO LIKE NEW.
THE BLUE INTERIOR IS I'M TOLD VERY RARE AND SORT AFTER.
THE INTERIOR IS IN NEAR PERFECT CONDITION APART FROM A VERY SMALL HOLE THE SIZE OF A 5 PENCE PIECE IN THE DRIVERS SEAT. AND ONE IN THE ROOF LINING, COMES WITH A HEAD UNIT AND DOOR SPEAKERS
ALSO THE BOOT CARPET GOOD DO WITH A SCRUB BUT THATS ONLY IF YOU'RE FUSSY.
THE BODY WORK POLISH'S WELL AS YOU CAN SEE FROM THE PICTURES APART FROM ONE REAR WHEEL ARCH
AND THE FRONT NEARSIDE (PASSANGER) THERES A DENT AND SCRAPE, HOWEVER AN EASY FIX OR JUST RIDE IT AS IS. (REALLY DOESNT LOOK BAD AT ALL-RAT LOOK?)
SLAMMED ON AUDI 80 SPRINGS WITH STEEL RIM'S & LOW PROFILE TYRES
ALSO INCLUDED IN THE SALE:
IS THE 5 ORIGINAL B2 PASSAT WHEEL'S WITH TYRES.
BRAND NEW BOXED CLUTCH PLATE
BRAND NEW BAGGED CONTROL CABLE
BRAND NEW BOXED BREAK SHOES
BRAND NEW BOXED BREAK PADS
BRAND NEW BOXED BREAK PADS (SECOND SET)
BRAND NEW BOXED BREAK DISCS
THE ORIGINAL SPRINGS
THE PASSAT DOESN'T NEED ANYTHING SPENDING ON IT THESE WHERE PURCHASED ALONG THE WAY FOR IF/WHEN PARTS NEEDED CHANGING.
REMEMBER THIS IS A 30 YEAR OLD CAR SO IS NOT SHOWROOM CONDITION BUT PRETTY CLOSE!
THIS IS MUCH COOLER AND MUCH MORE RARE THAN MOST VW'S,
MOT TILL END OF NOVEMBER & TAX DOES RUN OUT END OF JAN
ANY INFORMATION PLEASE CALL/TEXT 07815602776
ONLY SELLING DUE TO NOW HAVING A COMPANY CAR, CAN'T JUSTIFY HAVING IT ANYMORE, WANT SOMEONE TO LOOK AFTER IT AND MAKE IT INTO THE CAR IT SHOULD BE. tho IF the right P/X came along I could be tempted!
Sorry for shouting I got through most of this before I realised the caps lock was on!
X2 KEYS
