Jan 27, 2013 11:38:56 GMT
This got delivered earlier and my intention is to convert it into a motorcycle table lift.For those that don,t know it,s an NHS hydraulically operated bed that tilts as well as raising/lowering. First job will be to remove the bed frame.
If I had two brains I,d still be a halfwit 1969 Morris Minor Traveller
Jan 27, 2013 12:00:07 GMT
What a cracking idea, bookmarked!
bmw156
Jan 27, 2013 12:09:42 GMT
I work for a firm which manufactures variable height couches very similar to this. We have often thought about doing this.
Jan 27, 2013 12:17:49 GMT
thats a brilliant idea, where did you get the bed from?
Jan 27, 2013 12:46:22 GMT
Got it off e-bay £72,delivered by shiply £48 quite a saving on a commercial lift.
Jan 27, 2013 13:46:47 GMT
Bed frame removed ready to have a section sliced out and welded back together.
Jan 27, 2013 14:00:35 GMT
Good project. Nice idea.
Jan 27, 2013 14:02:37 GMT
Cracking idea !!! Top man. I'd never have thought of that ....... (Worse bit is ...... i saw some being skipped last yr )
Jan 27, 2013 14:30:53 GMT
I work at a large hospital and see these being thrown out/scrapped weekly as we get the new Sidhill profiling beds. I spoke to the rep from Sidhill a while ago and mentioned converting beds into motorbike lifts. He said, if the bed is rated at, say, 180kg, it will have been tested to 360kg. I thought this was perfect as all the bikes I come into contact with are around 200kg or under. Clinic-style beds/couches are more compact but have a slightly lower weight limit and less adjustability. Richy, If you need any hydraulics or castors etc, let me know and I'll wheeech (local slang for pinching :-) ) them before the beds get skipped.
rod
Jan 27, 2013 15:59:31 GMT
Thread hijack...sorry..whats the story on the car in the background of the bed shots?
Jan 27, 2013 16:46:51 GMT
Mercman, thats good to know about the mass capacity.
I tried to post this morning but the phone crashed for some reason when I hit the post button.
I had previously thought abut this but then forgot about it again.
Great project Richy.
Jan 27, 2013 16:48:58 GMT
Hi Rod, If you,re the Rod I think you are then it,s your old Amazon. Tony.
Jan 27, 2013 17:55:29 GMT
Jan 27, 2013 23:14:31 GMT
I Love this idea!
bmw156
Jan 28, 2013 10:31:32 GMT
I can indeed agree with Mercman, We test our beds to a lot higher then they need. our hydraulic are rated at 180kg, and our electric are rated to 260kg, with some bigger ones rated to 50 stone, what ever that is in kg.
I also have a large stack of old couches out the back of our factory! lol
Jan 28, 2013 19:31:54 GMT
I think that, when they test the beds, they probably take into account the amount of visiting family members that sit on the beds too which is, incidentally, against NHS HAI policy!...(jobsworth mode off now! :-) )
Jan 29, 2013 18:02:02 GMT
Its because its used for lifting people, as opposed to goods, so the safety factor rating is greater than an engine crane for example.
luckygti
I need to try harder!
Jan 29, 2013 20:48:20 GMT
What a cracking idea, how high does it go?
Jan 30, 2013 10:26:20 GMT
SWL (safe working load) is nearly always a minimum of HALF the weight needed before things start to bend/break - car ramps are a good example
Jan 30, 2013 19:17:19 GMT
Polyester slings have to be tested with a safety factor of 7 : 1. Thats for lifting goods.
