Hi Folks,
1987 BMW 318i with the M10 engine.
Happened once yesterday and then again once today so definitely intermittent, basically every now and then when it starts up the starter is failing to disengage once the car has started in so much as I can turn the ignition off and take the key out and it still sounds as though the car is turning over.
I'm guessing its the solenoid at fault here, any tips for a quick fix?
Cheers,
John.
Cheers,
John.
