Jan 19, 2013 17:19:02 GMT
I've looked for this EVERYWHERE on the net and Hayne's manual and can't find it.
Can someone put me out of my misery and tell me what it is? There are 6 (I think) marks on the crank pulley - which I assume is -5 0 5 10 15 20.
I've got everything to do it with, I just don't know what the timing degrees is!
Jan 20, 2013 14:43:36 GMT
right. i've dug out the haynes manual. section 13.73 and 13.74 and it basicly says... the procedure is as discribed in chapter 4
Last Edit: Jan 20, 2013 14:44:45 GMT by Al Ramone
Jan 20, 2013 21:02:01 GMT
Lol I've lost my Haynes manual!!
Jan 20, 2013 21:07:54 GMT
Shame, had a manual in the one I scrapped the other week.
Jan 21, 2013 18:27:27 GMT
to be honest. the haynes is pretty rubbish and doesn't show proper pics of the 12valve engines timing marks. instead, it just tells you to set it up like the 1.3 and 1.6 engines. 1.3 is 2, +/-2 and 1.6 is 4, +/-2
there is a fair amount of pluming to the dissy vacum advance/retard too, so if any of them pipes is split or not conected up right it's never gonna run as it's ment to.
the dissy on mine is set pretty much bang in the middle of it's adjustment.
Last Edit: Jan 21, 2013 18:29:46 GMT by Al Ramone
Jan 21, 2013 18:31:27 GMT
oh and make sure you do the timing with the engine up to temp to make sure the vacum control valves are open.
Jan 21, 2013 20:58:14 GMT
Thanks for that - I checked my Bluebird manual and it has all the timing detailed on the crank (as listed above). The previous owner changed the vacuum hoses (there's four going into the carb alone) and it's possible this is the problem - now where to find the digram for this! My Starion had a complete diagram for it, wish I could find one for the Sunny!
Jan 21, 2013 21:05:20 GMT
there's a good diagram in the haynes! ;D
Jan 21, 2013 21:17:47 GMT
ok. just found the correct ignition timing for the GA14S..
dissy vacume hoses disconected and plugged. set at 800rpm. 2* ATDC +/-2*
so there ya go.
Jan 22, 2013 14:24:50 GMT
Thanks for all your help, I really appreciate it! I'll give it a go as soon as I'm over this chundering (etc) into the toilet business.
