Alright I have 4 wheels with 2x tyres 185 wide and 2x 165 wide. These are just what I have so unless you think its dangerous please don't suggest buying another 2 185s
These are to go on my Peugoet 205 xs (front wheel drive)
I was planning to put the wider ones on the front as they do most of the work. I know they'll fit as many put 185s all round.
Is that sensible? Or better to have the 185s on the rear?
Cheers
Jan 18, 2013 10:09:42 GMT
It won't make a lot of difference either way really. People usually suggest putting the wider ones on the rear since wider tyres "usually" have more grip, so you'd end up biased towards understeer which generally considered safer, however wider tyres don't always have more grip (on snow, through standing water etc) so it's really 6 of one, half a dozen of the other.
It'll probably look a bit weird with bigger tyres up front though.
bl1300
Jan 18, 2013 10:16:58 GMT
I had bigger 155s on the front and 145s on the back of my daf for a few months a couple of years back. Apart from knocking the speedo out a bit you really couldn't tell the difference.
Current fleet.
Jan 18, 2013 10:36:05 GMT
Not a problem if they're reasonably decent tyres. It's not uncommon with fwd race/rally/sprint cars to put bigger tyres on the front - it's where all the work is done.
V8 MGB GT sprint and track V8 Ford Pilot Woodie project 1971 Early Bay VW camper
Jan 18, 2013 10:56:04 GMT
When you fit new tyres it's advisable to have them on the rear even if it means swopping the existing rears to the front first. The reason given is that you need the most grip on the rear so in the even of a skid it's the front that breaks away first and that is easier to control than a rear letting go. Same COULD apply if you have wider front tyres and therefore more grip on the front. On a rally car the drivers probably use the rear breaking away to their advantage but personally I'd prefer all wheels to remain firmly planted all the time !
Paul H
wider tyres on the front?stealthstylz
@stealthstylz
Club Retro Rides Member 174
Jan 18, 2013 10:57:11 GMT
I used to run 195/50 15 Eagle F1s (front) and 165/70 14 Colway gravel tyres (rear) on my Clio and it drove perfectly for me, but I tend to use the rear end dancing about to kill understeer.
Jan 18, 2013 11:09:45 GMT
Hmm composimmonite that interesting, I guess if I run the 165s on the front they'll get worn down quicker then I buy new 185s when I have to (swap them to the rear) and have same all round.
Not worried about how it looks.
Still tempted to put them on the front though. See if anyone else recommends/has used wider on the front?
Thanks guys
CIH
Jan 18, 2013 15:02:17 GMT
Audi RS3 has wider tyres front than rear. Makes about zero % sense tho....
Last Edit: Jan 19, 2013 16:46:19 GMT by CIH
Jan 18, 2013 19:26:35 GMT
there's more weight over the front (generally) so if you put the wider tyres on the rear, you run the risk of LESS grip at the rear. An exaggerated way of thinking about it, what would be harder to push: A) a 4 legged table, with 300kg weight B) a large flat-bottomed box that weighs 300kg It seems a bit strange, but generally, the table would be harder to push, as there's a higher concentration of force at the contact patches. I've also got personal experience of this - my scimitar was turned into a pickup (ie: naff-all weight over the rear) and it had HUGE rear tyres. It spun-out all the time, and was just a pita... Shove them on the front, and you should see a tiny smidgen of a gain of grip (in theory)
Jan 18, 2013 20:05:24 GMT
Personally I would put the new ones on the front initially, as tyres take bloody ages to wear in on the back of a pug.
Jan 18, 2013 23:10:54 GMT
it's not just the "wear" of a tyre that degrades grip - it's thermal cycles, UV, and oxygen that degrade them.
So even if it's never moved an inch, a 3 year old tyre, will have far less grip than a new one
Thanks for the detailed reply Chairchild (and others) think I will shove them on the front as planned then!
Jan 20, 2013 14:49:52 GMT
Right so I put them on all fine, but while tightening (by hand) one of the rear wheel bolts I sheared it :(and its stuck in the wheel still.
Happened to me before, am I simply too manly for the puny bolts? The brace I was using slides out so is reasonably long, and I think the force generated may be too great so I used the short one that comes with the car to do the rest.
Another trip to the garage to get that sorted :\
bortaf
Jan 20, 2013 16:05:30 GMT
Just to get some balence to the discussion (sorry ) On my truck i had 195s all round, loads of out action, then fitted 2 new 185's on the rear and now it's understeer city ! size makes curse word all differance if the tyres are of differant age/construction/tread type ect
R.I.P photobucket
niwid
Jan 21, 2013 21:11:54 GMT
I used to have a corsa diesel. When i needed some cheap tyres I ended up buying 2 second hand wheels with decent tyres. Didnt realise that they were 145 wide rather than 165. Put them on the front and its was awful, understeering every oportunnity. Swapped them onto the back, and it was considerably more fun than when it had the wider tyres on the back!
Never felt like the back end was gonna come out though, even under heavy braking
It did have a chunky diesel engine up front though, so all the weight was on the fronts.
CIH
Jan 22, 2013 18:42:58 GMT
Right so I put them on all fine, but while tightening (by hand) one of the rear wheel bolts I sheared it :(and its stuck in the wheel still. Happened to me before, am I simply too manly for the puny bolts? The brace I was using slides out so is reasonably long, and I think the force generated may be too great so I used the short one that comes with the car to do the rest. Another trip to the garage to get that sorted :\ Depends how balls-out you went but if the bolt were ok it would take considerable overtightening, not the sort of thing you could by hand without meaning to do so.
bl1300
Jan 22, 2013 19:09:12 GMT
Yeah ive had a car that I had to put a scaffold tube over the biggest breaker bar I have to get the wheel nuts off, someone had done them up that tight without snapping them. I know I can undo a crank bolt tightened to 186Nm with that bar so those wheel nuts where bloody tight!
Current fleet.
Jan 22, 2013 23:19:35 GMT
Right so I put them on all fine, but while tightening (by hand) one of the rear wheel bolts I sheared it :(and its stuck in the wheel still. Happened to me before, am I simply too manly for the puny bolts? The brace I was using slides out so is reasonably long, and I think the force generated may be too great so I used the short one that comes with the car to do the rest. Another trip to the garage to get that sorted :\ Depends how balls-out you went but if the bolt were ok it would take considerable overtightening, not the sort of thing you could by hand without meaning to do so. I think cross threading is the cause tbh
