fred
WTF has happened to all the Vennies?
Blimey its for sale in my area Not sure about the legality MOT wise But I sure can see where your coming from rather like a regal bucket seat
'79 Cossie ran Cortina - Sold
2000 Fozzer 2.0 turbo snow beast
'85 Opel Manta GSI - Sold
03 A class Mercedes
Looking for a FD Ventora - Anyone?
Nope.
I can't speak from an MOT point of view as I am not a tester, but safety-wise its a bad idea. Firstly, these things are wooden framed, and pretty flimsy too. There is no way to easily fix it to a car floor securely enough so that it wont just pull apart in the event of a crash. Secondly, the shape of the seat will hold the seatbelt quite far away from your body, so even in a minor bump you will shoot forwards before being brought to a sudden stop by the belt, or even just sliding under it. This is the reason its not advisable to use a normal seatbelt with many bucket seats.
If you used a multi-point harness and cut suitable holes, and reinforced them at the relevant points to allow the belts to pass through, removed the entire wooden frame and fabbed a replacement in steel, then refitted the padding and cover, then maybe it would be ok. Maybe.
fred
as dave said, I was mulling over this and its the wooden aspect of it all cutting a slot through the wing bit to allow the belt to pass wouldnt be too much of a chore its the ''making it safe' bit take some effort and thinking
03 A class Mercedes
its also probably about a foot wider than a normal car seat too
Jan 18, 2013 11:08:57 GMT
Ok that's pretty much what I thought. I may look into using an existing seat frame and "reshelling" it as such Cheers for the help chaps
Jan 18, 2013 11:09:37 GMT
Actually although I think the idea is horrendous it might be possible. Look at the seats people make and fit into hot rods ? Timber frame isn't such a negative as it was a common method for the seat frame on "quality" cars in the past. Morgan still have timber body frames, early Marcos had wooden chassis and Morris Minor Traveller had structual timber so it is well used in vehicle stressed areas.
Paul h
Jan 18, 2013 20:26:08 GMT
Hahahaha!
Jan 18, 2013 21:18:56 GMT
would be rude not to leave this video here ;D ;D
