Tell me about: BMW 525e (e28)Robinxr4i
@robinxr4i
Club Retro Rides Member 143
Jan 24, 2007 13:00:53 GMT
Although I want a Sierra (due to general lower running and buying costs) I keep seeing a E28 525e for sale its only £395 with 12 month mot and it's in good nick. It ticks most of my boxes RWD, bigger engine and old skool.
Just wondering about.....
Parts standard/modified? Performance? Running costs? Ease to work on?
And what the bloody hell does "e" stand for? Better not be the dredded word "economy"?
Last Edit: Jan 24, 2007 22:48:53 GMT by Robinxr4i
bryn
Jan 24, 2007 13:09:50 GMT
Although I want a Sierra (due to general lower running and buying costs) I keep seeing a E28 525e for sale its only £395 with 12 month mot and it's in good nick. It ticks most of my boxes RWD, bigger engine and old skool. Just wondering about..... Parts standard/modified? Performance? Running costs? Ease to work on? And what the bloody hell does "e" stand for? Better not be the dredded work "economy"? I rate them, it'll be an auto unless it's been converted but don't let that put you off. I nearly bought one instead of a 528i, there wasn't that much difference in performance and it did nearly 30mpg on a 400mile round trip at excessive motorway speeds. As far as modifications go, anything you want is available for all the usual prices (ie nothing is a problem or too expensive). That sounds like a good price too, just watch out for rust and that the autobox functions well. E28s like bushes too... The rubber kind that is, so make sure they're not fubarbed too. I'm sure more people will be along soon with more info. ;D
Jan 24, 2007 20:09:31 GMT
well the bottom end will make £250 if you sell it on to an e30 owner. basically it uses a long stroke crank and rods to acheive 2.7l out of a 2.5l block. uses an e21 style head with tiny ports and valves, for economy, as it was an economy model. uses super tall gearing and redlines at 4.5k rpm. also 520i sized inlet manifolding. now for the fun part ;D use a 325i head, inlet manifold, iTB and wiring (inc. ecu and airflow), that will open it up dramatically. modified ITB, replica alpina chip, all that lot will give you a dyno proven 180+bhp and gob-loads of torque. its not the "best " way, but is the cheapest manual 'box from a 325i is a shrewd move too. final drive gearing is adaptable too, the 525e uses the e30 325i diff, but with different ratios, if they weren't being hunted in packs at the mo, I'd recomend an LSD. rear axle isn't as good as the 528i, suffers from too much camber change in aggressive cornering, but springs and maybe some camber adjusters would sort some of that out. m535i brakes go on too, for uprated stoppers. watch out for the external brake linkage seizing up, its a PITA if it does. rear axle bushes are favourites (like bryn says), not exactly a diy job unless you drop the axle and burn the old ones out! we used to do this at work, but we have had a special tool for some years now, makes life much easier and the "e" stands for ETA, not sure what that is tho. never really cared either. great and hugely underated cars, mainly because of the economy stigma I reckon.
Jan 24, 2007 22:06:52 GMT
ETA comes from the Greek letter 'eta' and is used by the Germans to mean 'efficiency', apparently.
Prius T-Spirit, Alfa 156 Sportwagon, Alfa 75 TSpark Veloce, Mazda MX-5 1.8iS Honda VFR750FT, Ducati 750SS, BMW R100RT, Hongdou GY200
@robinxr4i
Jan 24, 2007 22:17:52 GMT
I am slightly put off by the fact its an automatic, only seen it from a distance. Oh well it might still be worth a look!
Jan 24, 2007 22:29:16 GMT
yes nice cars, but wasnt there something about tyres on them being very very expencive on those run flat jobbies?
they can be changed like...
bryn
Jan 24, 2007 22:31:26 GMT
I know what you mean about the auto part, I guess it depends on the intended use but I found it a pleasant change and like I say the performance was still good. Plus any E28 on a set of decent rims looks fast enough. Just noticed you're fairly local to me, I was in Paignton all weekend as it happens... Anyway, I use Fritz's Bitz near Wellington and they've got loads of E28 bits and put the M5 motor in my E28, so are more than capable of good advice. 'Metty' who joined here the other day and posted pics of his Mitsi motored Corrola works there.
bryn
Jan 24, 2007 22:32:14 GMT
yes nice cars, but wasnt there something about tyres on them being very very expencive on those run flat jobbies? they can be changed like... Some E28s came with Metrics? Loads of wheel options out there
@robinxr4i
Jan 24, 2007 22:45:42 GMT
I know what you mean about the auto part, I guess it depends on the intended use but I found it a pleasant change and like I say the performance was still good. Plus any E28 on a set of decent rims looks fast enough. Just noticed you're fairly local to me, I was in Paignton all weekend as it happens... Anyway, I use Fritz's Bitz near Wellington and they've got loads of E28 bits and put the M5 motor in my E28, so are more than capable of good advice. 'Metty' who joined here the other day and posted pics of his Mitsi motored Corrola works there. True on the right set of wheels and a good hard lowering will make it look like nice a fast n mean motor. The car is in Paignton as a matter of fact wierd that... I guess? Gonna have a proper poke around it this weekend see if its a good as it look from a far!!!!!
Last Edit: Jan 24, 2007 22:47:55 GMT by Robinxr4i
Jan 24, 2007 23:57:19 GMT
Ive always had a soft spot for them. Would quite like to have one as a daily for me.
I looked at one a while ago. Should have bought it instead of the Chrysler...
The 525e is a different animal to the regular 520, 525 or 528. I looked into them via someone I came across who knew his e28s. It actually only makes about the same power as a 520 - something like 115 BHP IIRC. Designed as a cruiser not a bruiser. Big MPG meter on the dash should be the clue what this car is all about.
Could well be nice if thats what you want.
Jan 25, 2007 18:03:29 GMT
Big MPG meter on the dash should be the clue what this car is all about. all e28s bar the lowest spec 518 carbs and the m5 (which had an oil pressure gauge instead) had a "swing-o-meter". they're great at traffic light grand prix. 11:1 compresion seems to help it off the line. I do like e28s, seen less and less of them at work now. hopefullly only the good ones remain in circulation. maybe we'll drag the turbo'd one out of hiding and get it running properly. turbo e28 Q car FTW!
