pair of bbs rx2 split rims in need of major refurb
4x100
15x6j
et42
57.1 centrebore
wheels have been split, but most of the bolts were siezed (out of the pair, only 5 bolts came out) so the heads had to be drilled off. the threaded parts are still in the barrels and either need to be removed or ground flat and new holes drilled and tapped. I have since bought a pair in better condition, so no longer need these, and can't be bothered to carry on with refurbing them.
one of the barrels has a bit of a chip out of it that would need filling, or welding if you wanted to keep the polish/diamond cut lip they have as std. i had planned to paint them, so was going to fill.
collection only, no couriers
from chipping norton, oxon
£40ono
