does anyone have a haynes manual that has a pinto in it? i need some measurments of stuff like the crank and pistons and valves and oil pump ect... for my uni project. if anyone in or around leeds/wakefiled that could lend me it for a few days that would e great or if anyone can scan a few pages and send them to me? i will repay your kindness with beer ;D thanks
njw
Dec 27, 2012 16:32:03 GMT
Got a manual for the mk3 Granada here, it covers the 1.8 and 2.0 Pinto, I've never used my scanner but I'll try and suss it out if you let me know what you need to know.
Dec 27, 2012 17:30:32 GMT
that would be awesome, i need the pages that list the manufactures spec of the crank(end float,main bearing ect) oil pump, valve sizes and wear, piston sizes, bore size. basically all the manufactures specifications for the engine internals
Dec 27, 2012 18:18:17 GMT
I've got a Mk3 Cortina Haynes here, what size engine are we talking about?, 1.6 or 2.0?
Dec 27, 2012 21:39:36 GMT
i think i stripped down a 1.8 or 1.6, one of the other guys had bigger pistons than me (always the case lol)
Dec 27, 2012 23:47:15 GMT
That would be a 1600 pinto then as they never made a 1800, it's too late now but if i remember I'll scan you some pages tomorrow.
82bob
Dec 28, 2012 10:21:59 GMT
The 1.8 L (1,796 cc) Pinto engine was introduced in 1984 as a replacement for the "old" 1.6 L. The engine had an 86.1 mm (3.39 in) bore and 77.0 mm (3.03 in) stroke giving the displacement of 1796 cc. Output was 66 kW (89 hp) of power and 140 N·m (100 ft·lbf). Fuel was supplied by the Pierburg 2E3 28/32 carburetor. Applications: 1984–1989 Ford Sierra (engine codes REB, RED, REF) 1985–1992 Ford Scorpio (engine code REC)
bortaf
Dec 28, 2012 13:26:39 GMT
yeh the 1800 pinto was an under bored 2.0 this do ya ?
R.I.P photobucket
Dec 28, 2012 16:59:12 GMT
thats amazing mate do you have anything on the valves and oil pump?
Last Edit: Dec 28, 2012 17:00:06 GMT by richlyons
Dec 28, 2012 23:06:15 GMT
I have a mega tatty Capri manual (no cover, greasy, got wet once). Happy to remove any pages you need and post them to you for future reference if you want.
Jaguar S-Type 3.0 SE
Dec 29, 2012 19:46:17 GMT
thanks for the offer mate, ill get in touch if i need to take you up
