Dec 16, 2012 13:42:23 GMT
I know that its wrong but..
can you chop springs when they are on the car or do you have to remove them? whats the best way to do it? the car which ill be doing it to is an e28 bmw
thanks shane
benmk1
Dec 16, 2012 14:12:06 GMT
I don't think you can do it mate as your springs are pigtailed.
Either way do not do it on the car, they will be under compression and you will have a very nasty accident
Dec 16, 2012 14:21:45 GMT
Off the car , the ride usually suffers as well personally I would save up
CHOPPING SPRINGS...ChasR
@chasr
Club Retro Rides Member 170
Dec 16, 2012 18:05:52 GMT
I don't think you can do it mate as your springs are pigtailed. Either way do not do it on the car, they will be under compression and you will have a very nasty accident A couple of well known members have chopped their springs on the car. Whilst some may claim it is safe (an in some instances it probably is not too dangerous (I.E when the spring is not compressed at all) I would still take the springs off the car in all honesty if you are chopping them:).
mat91
Dec 16, 2012 18:37:18 GMT
Cutting springs on a car is fine done it many times you just have to under stand were the force will push so not to trap.the cutting.disc etc but if your worried ie starting a thread on it then remove them
The stupid is everywhere
rodney
https://www.facebook.com/RD-vehicle-transport-and-recovery-services-525622614268010/
Dec 16, 2012 22:18:16 GMT
if you have to ask then cut em out the car if they aint pig tailed at both ends, otherwise just buy some springs,.
facebook: rodney dean / rd transport
Dec 16, 2012 22:45:35 GMT
they don't make springs short enough for what I'm after. ill just jack it up and have a look when ive got a day off work. thanks anyway
v8ian
Dec 17, 2012 18:23:28 GMT
Double pig tailed, and a right horrible job to remove, I made a compressor to remove them, as the normal type compressor I had would not go around the spring. Cutting double pigtails is nigh on impossible as they get bigger towards the centre so if you cut them the spring wont fit in the cup, MOT fail and potentially dangerous if the spring slips off the cup. Buy aftermarket ones, much much safer,
bl1300
Dec 17, 2012 18:38:23 GMT
Please don't cut pig tailed springs they will not seat properly afterwards and could be potentially dangerous.
Current fleet.
MrSpeedy
East Midlands
www.vintagediesels.co.uk
Dec 17, 2012 18:50:03 GMT
It's not cutting them on or off the car that is the issue, it's doing under load that is the potentialy dangerous bit
As for ride quality, ANY lowering spring WILL stiffen teh ride. This is obvious as the suspension cannot travel as far before things start bottoming out!
I've done it both ways, My old W201 190E had proper lowering springs and my current W124 300CE has had 2 coils removed all round. Both had low profile tyres (45's on 17's and 40's on 18's) and tbh I'd say the 300CE still rides better.
However, if your car has double pigtailed springs (I'm unfarmiliar with BMW's) then all the above is pointless as you cannot re-seat them after chopping.
If there's nothing listed for your application, try looking at other applications as you'll probably find something similar somewhere. eg, IIRC putting Corsa rear springs in to lower Astra/Cavaliers is not unusual. (However this may be factually incorrect!)
rodney
google a spring company , they will make any type you want,.
Yep, springcoil or coilspring in Sheffield, either are happy to do custom springs, I've had loads done.
Dec 19, 2012 15:08:46 GMT
Iam with phillipm Coustom springs and some blisten dampers B6 or B8 should do the job very nicely. For the spirings i think spax do an ok set for around 130 and the damper dependent on type around 400 don't cut the springs.!!!!!!!!! Nice E28 btw if you want to sell or swap it let me know. Cheers
The louder you Scream the faster we go
