mfrv1
I'm looking to replace the side repeater on Dad's Cinquecento Sporting with something less... round. I'm looking for suggestions, measurements etc. As way of opologies for this tedium, here's some pics from Facebook: And something a little festive:
I usually just go down the scrapyard and grab some that I like the look of. Round, oval, oblong and triangle are easy enough to get hold of, then just file the hole in the wing out to the right shape and bung em in.
What about LED items in the edge of the mirrors ?
v8ian
Dec 12, 2012 13:20:16 GMT
what about deleting them altogether?
Copey
Dec 12, 2012 13:32:10 GMT
what about deleting them altogether? this
Dec 12, 2012 14:42:14 GMT
Dec 12, 2012 18:28:04 GMT
what about deleting them altogether? AAARRRGGGHH!!!!!!
awoo
Dec 12, 2012 19:14:46 GMT
honda s2000
Dec 12, 2012 19:28:04 GMT
I use fiat 126 repeaters on mine suit the car a lot better than the round ones IMO they needed fettling to fit mine are also screwed in from the back the wiring connector also needs the wiring connector cutting off and replacing with spade connectors
it's not the holes that are rotten it's the metal around them
1975 trabant 601s deluxe
1987 trabant 601 Kombi
1996 fiat cinquecento 1.4 16v
Dec 17, 2012 23:39:36 GMT
Stuck bog standard Ford repro items on mine because they was cheap, I was skint and they were the same colour as the front indicators. Took a few minutes with a file to adjust the holes to suit. Daubed a bit of paint on and pushed the new ones in- they just clipped in and stayed put. I forget what did with the wiring. I think I crimped some butt joints onto the wiring. So long as you don't drop it inside, it can all be done without having to take the plastic inner wheelarches out. I'd looked at the newer ones as put on the Fiat Coupe' too, but Fiat at the time wanted too much for a pair. --Phil
Iain
Dec 17, 2012 23:42:51 GMT
I like the look/shape of the Astra mk4 side reps.
EmDee
Committer of Autrocities.
Club RR Member Number: 108
Dec 18, 2012 10:04:24 GMT
Dec 19, 2012 18:42:01 GMT
I just bought some of these this morning *doesahappydance*
mfrv1
Are there such things as cool side repeaters?
VWPowered
No-Rice - Est 2002
yes
81 Bedford CF 2.3D Cavalier Coachman Stratus 86 Volkswagen Polo Mk2 1.6 8v 87 Austin Montego 1.6HL 'Daily' 91 Rover Montego 2.0TD Countryman Estate 93 Rover Montego 2.0LXi Estate
mfrv1
Dec 22, 2012 22:47:29 GMT
Little note: Cavalier lenses don't fit Cinquecentos.
