Dec 11, 2012 21:33:06 GMT
The indicators have stopped working on my mk2 escort. At first I thought it was a bad earth at the lights but I've double checked that and it seems to be ok. Yesterday I thought it might be the stalk as my main beam and headlight flash wasn't working but I had a look again tonite and that's working now, so now I'm thinking that the relay might be at fault, when I push the hazard switch just the front indicators flash all be it not very bright the rear lights also flicker in time with the front indicators. I really want this sorted as I was really hoping to take it for an MOT on Saturday morning.
Dec 11, 2012 22:17:45 GMT
dunno fords but VW work on different relays for indicators and the hazards, try swapping 'em ?
Dec 11, 2012 22:21:41 GMT
Cheers I will give that a go there's a rely right next to it so will swap them and see
taurus
Dec 11, 2012 22:28:15 GMT
If the fronts are working at all then it's unlikely to be the relay that has failed, if they go you tend to get nothing at all. If both sides are doing the same I'd take a look at the flasher unit. I had a similar issue and after checking all the wiring etc I finally fixed it by replacing the popple type flasher unit with a digital one. Works a treat now.
Dec 11, 2012 23:58:29 GMT
check the earth lead under one of the stalk mounting bolts is ok . also the rear light units are earthing properly.
only one relay.
theres more to life than mpg & to much power is just enough.
usually bad earths on fords, also try removing the indicator bulbs one at a time and trying again,might be one pulling down to earth. I've seen the connectors at the lamps fail,wiring troubles, it could be pretty much any of those but its a very basic system to fix.
Cheers I will strip it all down and have a good look, I've located another stalk to try too so fingers crossed
Dec 16, 2012 15:20:28 GMT
All sorted now, it was a bad earth at the drivers side rear light and the earth was shorting out on the rear indicator bulb on the rear passengers side
