Jan 18, 2007 23:32:40 GMT
SPLIT RIMS ARE FOR WINNERS
Jan 18, 2007 23:41:23 GMT
they do look good, VERY easy to make as well, but if you want them functioanl there is a very strict set of mathmatical rules to follw, as being even a tiny bit out makes em useless.
Seth
Jan 18, 2007 23:59:59 GMT
Oooo, yes, I'll have a few of them please ;D
Is it wrong that one of my earliest memories is reading a late-eighties/early nineties copy of CCC that had an article on vents and how effective they were...And that I've always remembered that a proper NACA duct is the best vent available (on a flow vs drag comparison)...?
I even remember the diagram, giving angles and radii that the duct should be....
*n
st182
'yota man
your not wrong functional indeed- they draw air into whatever they're connected to cant remember the exact reason why (I THINK air decompresses and therefore speeds up creating a ram effect) cos i aint been to college for a long time , but i learnt they worked there so i'll believe them ;D sexy too, form and function in one great package ;D If your worried about the shapes i think places like demon tweeks do pre-formed ones which you can "let in" wherever you like. If you're made of money, buy an F40 and cut out the bits you want, and fibreglass them to your *insert retro chariot here*
Dan '93 JZA80 '79 TA40 '99 SCP10
NACA ductsRobinxr4i
@robinxr4i
Club Retro Rides Member 143
I know it look cack cause I have not sprayed it (and I have lost faith with it so I am going to break it) but heres my NACA duct on my Volvo 480 turbo...... Mounted above my (mega heat soaking) filter cone! Yes they do look slightly better on a F40 though
Jan 19, 2007 11:02:03 GMT
If you're made of money, buy an F40 and cut out the bits you want, and fibreglass them to your *insert retro chariot here* Or take a look at the bonnet of a T72 (late '80s type) Bluebird. They have what's basically a big NACA duct pressed into them. Recall them being mentioned in the mag's in the early '80s, probably an essential part of getting the IMSA look on your Princess
Jan 19, 2007 11:08:01 GMT
Brian Burrows modelled the ones on his Squareback on the ones from his GT40 Replica...
NACA ductsDeleted
@Deleted
Jan 19, 2007 12:02:00 GMT
your not wrong functional indeed- they draw air into whatever they're connected to cant remember the exact reason why (I THINK air decompresses and therefore speeds up creating a ram effect) cos I aint been to college for a long time , but I learnt they worked there so i'll believe them ;D Not quite, an external duct makes better ram pressure than a flush duct but makes more drag. If you just want a bit of intake but don't want to naff up the aerodynamics then a flush duct like this NACA duct works better. Check oot the description here: en.wikipedia.org/wiki/NACA_duct
Last Edit: Jan 19, 2007 12:03:04 GMT by Deleted
Anglia68
Powered By Boredom.
Jan 19, 2007 15:39:02 GMT
Not forgetting...............
Anglia68
Powered By Boredom.
Jan 19, 2007 15:43:24 GMT
......................and one in the roof.
Last Edit: Jan 19, 2007 15:44:00 GMT by Anglia68
Jan 19, 2007 15:45:54 GMT
Cool. Twin NACA ducts for the RV8 then when I change it's plenum ;D
Jan 19, 2007 16:00:59 GMT
I run em on my imp look and That one feeds the turbo through the inline air filter theres anotherone for the other side to feed the intercooler
Jan 19, 2007 17:34:28 GMT
i remember 924 turbos have got one of them
