OUTRUN
Anyone know if vehiclewiringsolutions or similar make a plug to fit the OE spotlight etc connectors on a Ford loom? The double connectors in the pic below. As you can see, they are a male and a female bullet connector, I would rather not use singular bullets, as I want a fairly waterproof plug. Anyone able to help?
I need your help to get back to the year 1985.
bortaf
I had the same problem with my spotlight loom for my cortina, the male connector snaps off in the female all the time after it corrodes, i used a spare from an old cortina loom, there's one behind the dash and one on the heater motor that seem to last better.
R.I.P photobucket
v8ian
I don't think you will be able to buy these as an aftermarket item as they are a bonded/sealed on type plug
Cant see the pics as I'm at work offshore but try polevault for car electrical components,they'll most likely have something very similar. Failing that try a trip to a friendly, usually old, scrappy and search a few cars for the same plugs from a wiring loom, amazing what you'll find across various ranges.
