vitessetony
Club RR Member Number: 114
horn for aftermarket wheel?vitessetony
@vitessetony
Club Retro Rides Member 114
Hi all, I've fitted a nice mountney traditional wheel in place of the bus wheel origanally in the vitty. my question is how on earth (excuse the electrical pun) can I get a feed to the horn from the centre push button on the wheel without the twisted mess of wire I have at the moment? To explain, I have for the time being, just ran a wire from the horn push through the back of the wheel to the horn live under the dash when the button is pressed it contacts the wheel/coloumn and makes the circuit. the horn works but I'm concious that when I'm turning corners the wire will be twisting round the coloumn. not ideal.
MrSpeedy
East Midlands
www.vintagediesels.co.uk
Sounds to me like you haven't got the correct boss to suit your car.
I have an aftermarket wheel in my Vitesse using a mountney boss which has the proper carbon brush and ring.
vitessetony
@vitessetony
Could I ask where you got the boss from?
I had to use an astrali boss as its the only one I could find that would fit.
Thanks
MrSpeedy
East Midlands
IIRC mine came from a shop in Leicester who were mountney dealers. Can't remember the name I'm afraid. I can have a dig tomorrow if it helps?!
vitessetony
@vitessetony
If you don't mind that would be great thanks ;D It's difficult to find boss's for old obscure cars and mountney have ceased trading so its getting harder as they obviously don't make anymore!
v8ian
horns don't have to work off the button in the centre of the wheel, it can be worked from anywhere, simple switch on the dash will do,
vitessetony
@vitessetony
horns don't have to work off the button in the centre of the wheel, it can be worked from anywhere, simple switch on the dash will do, I wondered about that. I was 99% sure it could be operated from anywhere from an mot stance but I would like to run it from the wheel if possible. It's certainly something to bear in mind though, cheers
MrSpeedy
East Midlands
Right, Having cleared my brain of beer I can now tell you that I got the Mountney boss for my Vitesse from the TSSC. IIRC it was about £18 I probably went there cos they're only half an hr from me 01858 434424
i've got a button on dash in my t25 i had to put a little sticker on saying beep beep cause mot man could find it (read as couldn't be arsed looking for it )
years ago i had a nos button from demon tweeks wired to horn
vitessetony
@vitessetony
Right, Having cleared my brain of beer I can now tell you that I got the Mountney boss for my Vitesse from the TSSC. IIRC it was about £18 I probably went there cos they're only half an hr from me 01858 434424 Thanks mate i'll give them a try
vitessetony
@vitessetony
i've got a button on dash in my t25 I had to put a little sticker on saying beep beep cause mot man could find it (read as couldn't be arsed looking for it ) years ago I had a nos button from demon tweeks wired to horn Do you know if it has to be labelled for an mot or not?
not legally mine is black on a black dash he pressed steering nowt happened so failed it when i showed it to him he passed i only used sticker as a joke really
vitessetony
@vitessetony
not legally mine is black on a black dash he pressed steering nowt happened so failed it when I showed it to him he passed I only used sticker as a joke really Cheers, I should have a working horn soon then. I didnt really fancy a sticker unless I was going down the stripped out rally look.....now there's an idea. ;D
